AutoCAD 2024 开发者帮助
输入点滤波器和监视器示例
2024-5-18 19:12| 发布者: admin| 查看: 718| 评论: 0|原作者: admin|来自: AutoCAD
输入点滤波器和监视器示例
下面的示例演示了输入点筛选器和监视器的使用。
#include "adslib.h"
#include "aced.h'
#include "dbmain.h"
#include "acdbabb.h"
#include "adeskabb.h"
#include "rxregsvc.h"
#include "acgi.h"
#include "acdocman.h"
#include "acedinpt.h"
#include "dbapserv.h"
class IPM : public AcEdInputPointMonitor
public:
virtual Acad::ErrorStatus
monitorInputPoint(
    // Output. If changedTooltipStr is kTrue, newTooltipString
    // has the new ToolTip string in it.
    bool&                               appendToTooltipStr,
    char*&                              additionalTooltipString,
    // Input/Output
    AcGiViewportDraw*                   drawContext,
    // Input parameters:
    AcApDocument*                       document,
    bool                                pointComputed,
    int                                 history,
    const AcGePoint3d&                  lastPoint,
    const AcGePoint3d&                  rawPoint,
    const AcGePoint3d&                  grippedPoint,
    const AcGePoint3d&                  cartesianSnappedPoint,
    const AcGePoint3d&                  osnappedPoint,
    AcDb::OsnapMask                     osnapMasks,
    // const AcArray<AcDbCustomOsnapMode>& customOsnapModes
    const AcArray<AcDbObjectId>&        apertureEntities,
    const AcArray< AcDbObjectIdArray,
        AcArrayObjectCopyReallocator< AcDbObjectIdArray > >&
        nestedPickedEntities,
    int                                 gsSelectionMark,
    const AcArray<AcDbObjectId>&        keyPointEntities,
    const AcArray<AcGeCurve3d*>&        alignmentPaths,
    const AcGePoint3d&                  computedPoint,
    const char*                         tooltipString);
Acad::ErrorStatus
IPM::monitorInputPoint(
    // Output. If changedTooltipStr is kTrue, then newTooltipString
    // Input/Output
    AcGiViewportDraw*                   pDrawContext,
    bool                                pointComputed,
    int                                 history,
        acutPrintf("\nhistory: %d\n", history);
    if (pointComputed)
        acutPrintf(
            "rawPoint:                  %.2f, %.2f, %.2f\n",
            rawPoint[0],
            rawPoint[1],
            rawPoint[2]);
        if (history & Acad::eGripped)
            acutPrintf(
                "grippedPoint:          %.2f, %.2f, %.2f\n",
                grippedPoint[0],
                grippedPoint[1],
                grippedPoint[2]);
        if (history & Acad::eCartSnapped)
            acutPrintf(
                "cartesianSnappedPoint: %.2f, %.2f, %.2f\n",
                cartesianSnappedPoint[0],
                cartesianSnappedPoint[1],
                cartesianSnappedPoint[2]);
        if (history & Acad::eOsnapped)
            acutPrintf(
                "osnappedPoint:          %.2f, %.2f, %.2f\n",
                osnappedPoint[0],
                osnappedPoint[1],
                osnappedPoint[2]);
#define OSMASK_CHECK(x)  if (osnapMasks & AcDb:: ## x)
    acutPrintf("%s ", #x)
            OSMASK_CHECK(kOsMaskEnd);
            OSMASK_CHECK(kOsMaskMid);
            OSMASK_CHECK(kOsMaskCen);
            OSMASK_CHECK(kOsMaskNode);
            OSMASK_CHECK(kOsMaskQuad);
            OSMASK_CHECK(kOsMaskInt);
            OSMASK_CHECK(kOsMaskIns);
            OSMASK_CHECK(kOsMaskPerp);
            OSMASK_CHECK(kOsMaskTan);
            OSMASK_CHECK(kOsMaskNear);
            OSMASK_CHECK(kOsMaskQuick);
            OSMASK_CHECK(kOsMaskApint);
            OSMASK_CHECK(kOsMaskImmediate);
            OSMASK_CHECK(kOsMaskAllowTan);
            OSMASK_CHECK(kOsMaskDisablePerp);
            OSMASK_CHECK(kOsMaskRelCartesian);
            OSMASK_CHECK(kOsMaskRelPolar);
#undef OSMASK_CHECK
            acutPrintf("\n");
        acutPrintf("%d apertureEntities: ",
            apertureEntities.length());
        for (int i = 0; i < apertureEntities.length(); i++)
            acutPrintf("<%x> ", apertureEntities[i].asOldId());
        acutPrintf("\n");
    else {
        acutPrintf("No point computed");
        if (history & Acad::eCyclingPt)
            acutPrintf(", but new cycling osnap: %.2f, %.2f, %.2f\n",
                osnappedPoint[0], osnappedPoint[1], osnappedPoint[2]);
        else
            acutPrintf(".\n");
    if (NULL != pDrawContext)
        pDrawContext->subEntityTraits().setColor(2);
        pDrawContext->geometry().circle(rawPoint, 1.0,
            AcGeVector3d::kZAxis);
    else
        acutPrintf("ViewportDraw is NULL!\n");
    if (history & Acad::eNotDigitizer)
        acutPrintf("PICK!\n");
    if (NULL != tooltipString)
        acutPrintf("TooltipString: %s\n", tooltipString);
        additionalTooltipString = ", anotherString!";
        appendToTooltipStr = true;
    if (history & Acad::eOrtho)
        acutPrintf("Ortho found at %.2f, %.2f, %.2f\n",
            computedPoint[0], computedPoint[1], computedPoint[2]);
    return Acad::eOk;
class IPF : public AcEdInputPointFilter {
public:
Acad::ErrorStatus
processInputPoint(
    bool&                            changedPoint,
    AcGePoint3d&                     newPoint,
    bool&                            changedTooltipStr,
    char*&                           newTooltipString,
    bool&                            retry,
    bool                             pointComputed,
    int                              history,
    const AcArray<AcDbObjectId>&     pickedEntities,
    // Of 0th element in pickedEntities.
    // AutoSnap Info:
Acad::ErrorStatus
IPF::processInputPoint(
    bool&                            changedPoint,
    bool&                            retry,
    bool                             pointComputed,
    int                              history,
    // AutoSnap Info:
    // Change the computed point to an offset of (0.2, 0.2, 0.2)
    // if the current computed point is an object snap point.
    if (pointComputed && history & Acad::eOsnapped)
        changedPoint = true;
        newPoint = osnappedPoint + AcGeVector3d(0.2,0.2,0.0);
        pDrawContext->geometry().circle(newPoint, 0.1,
    return Acad::eOk;
// Input point monitor
IPM my_ipm;
// Input point filter
IPF my_ipf;
// Installs an input point monitor.
void testipm()
    curDoc()->inputPointManager()->addPointMonitor(&my_ipm);
// Installs an input point filter.
void testipf()
    curDoc()->inputPointManager()->registerPointFilter(&my_ipf);
// Turns on forced entity picking.
void testfp()
    curDoc()->inputPointManager()->turnOnForcedPick();
// Disables the system cursor graphics.
void testcursor()
    curDoc()->inputPointManager()->disableSystemCursorGraphics();
extern "C" __declspec(dllexport)
AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void *p)
    switch (msg)
    case AcRx::kInitAppMsg:
        acrxRegisterAppMDIAware(p);
        acrxUnlockApplication(p);
        acedRegCmds->addCommand("mkr", "testipm", "ipm",
            ACRX_CMD_TRANSPARENT, testipm);
        acedRegCmds->addCommand("mkr", "testipf", "ipf",
            ACRX_CMD_TRANSPARENT, testipf);
        acedRegCmds->addCommand("mkr", "testfp", "fp",
            ACRX_CMD_TRANSPARENT, testfp);
        acedRegCmds->addCommand("mkr", "testcursor", "cursor",
            ACRX_CMD_TRANSPARENT, testcursor);
        break;
    case AcRx::kUnloadAppMsg:
        acedRegCmds->removeGroup("mkr");
        break;
    return AcRx::kRetOK;
GMT+8, 2026-10-29 00:31
