AutoCAD 2024 开发者帮助
AcEdJig 示例代码
2024-5-18 19:12| 发布者: admin| 查看: 814| 评论: 0|原作者: admin|来自: AutoCAD
AcEdJig 示例代码
本示例创建一个类,使用户能够通过选取椭圆的中心点,然后拖动以选择所需的长轴和短轴长度来创建椭圆。在拖动操作期间,用户可以随时看到椭圆的样子。
注意:
如果用户尝试使短轴比长轴长,则椭圆最终为圆形,因为半径比不能大于 1.0。
class AsdkEllipseJig : public AcEdJig
// This class allows the user to create an ellipse by
// picking its center point and then dragging to select the
// desired major axis and minor axis lengths.  During the
// drag operations, the user will be able to visually see
// what the ellipse looks like at any time.
public:
    AsdkEllipseJig(const AcGePoint3d&, const AcGeVector3d&);
    void doIt();
    virtual DragStatus sampler();
    virtual Adesk::Boolean update();
    virtual AcDbEntity* entity() const;
private:
    AcDbEllipse *mpEllipse;
    AcGePoint3d mCenterPt, mAxisPt;
    AcGeVector3d mMajorAxis, mNormal;
    double mRadiusRatio;
    int mPromptCounter;
// The following defines the constructor that accepts a point to be
// used as the centerpoint of the ellipse and the current UCS normal
// vector to be used as the normal for the ellipse.  It also
// initializes the radius ratio to a small value so that during
// selection of the major axis, the ellipse will appear as a line.
// The prompt counter is also initialized to 0.
AsdkEllipseJig::AsdkEllipseJig(
    const AcGePoint3d& pt,
    const AcGeVector3d& normal)
: mCenterPt(pt),
  mNormal(normal),
  mRadiusRatio(0.00001),
  mPromptCounter(0)
// This function creates an AcDbEllipse object and gets the
// jig started acquiring the necessary info to properly fill
// it in.
void
AsdkEllipseJig::doIt()
    mpEllipse = new AcDbEllipse;
    // Get the major axis vector from the user.
    // At this time, mPromptCounter == 0.
    setDispPrompt("\nEllipse major axis: ");
    AcEdJig::DragStatus stat = drag();
    // Get the ellipse's radius ratio.
    mPromptCounter++;   // now == 1
    setDispPrompt("\nEllipse minor axis: ");
    stat = drag();
    // Now add the ellipse to the database's current space.
    append();
// This function is called by the drag function to
// acquire a sample input.
AcEdJig::DragStatus
AsdkEllipseJig::sampler()
    DragStatus stat;
    setUserInputControls((UserInputControls)
        (AcEdJig::kAccept3dCoordinates
         | AcEdJig::kNoNegativeResponseAccepted
         | AcEdJig::kNoZeroResponseAccepted));
    if (mPromptCounter == 0) {
        // Aquire the major axis endpoint.
        // If the newly acquired point is the same as it was
        // in the last sample, then we return kNoChange so the
        // AsdkEllipseJig::update() function will not be called
        // and the last update call will be able to finish, thus
        // allowing the ellipse to fully elaborate.
        static AcGePoint3d axisPointTemp;
        stat = acquirePoint(mAxisPt, mCenterPt);
        if (axisPointTemp != mAxisPt)
            axisPointTemp = mAxisPt;
        else if (stat == AcEdJig::kNormal)
            return AcEdJig::kNoChange;
    else if (mPromptCounter == 1) {
        // Aquire the distance from ellipse center to minor
        // axis endpoint. This will be used to calculate the
        // radius ratio.
        // If the newly acquired distance is the same as it was
        static double radiusRatioTemp = -1;
        stat = acquireDist(mRadiusRatio, mCenterPt);
        if (radiusRatioTemp != mRadiusRatio)
            radiusRatioTemp = mRadiusRatio;
    return stat;
// This function is called to update the entity based on the
// input values.
Adesk::Boolean
    switch (mPromptCounter) {
    case 0:
        // At this time, mAxis contains the value of one
        // endpoint of the desired major axis.  The
        // AcDbEllipse class stores the major axis as the
        // vector from the center point to where the axis
        // intersects the ellipse path (such as half of the true
        // major axis), so we already have what we need.
        mMajorAxis = mAxisPt - mCenterPt;
        break;
    case 1:
        // Calculate the radius ratio.  mRadiusRatio
        // currently contains the distance from the ellipse
        // center to the current pointer position.  This is
        // half of the actual minor axis length.  Since
        // AcDbEllipse stores the major axis vector as the
        // vector from the center point to the ellipse curve
        // (half the major axis), to get the radius ratio we
        // simply divide the value currently in mRadiusRatio
        // by the length of the stored major axis vector.
        mRadiusRatio = mRadiusRatio / mMajorAxis.length();
        break;
    // Now update the ellipse with the latest setting.
    mpEllipse->set(mCenterPt, mNormal, mMajorAxis,
        mRadiusRatio);
    return Adesk::kTrue;
// This function must be implemented to return a pointer to
// the entity being manipulated by the jig.
AcDbEntity*
AsdkEllipseJig::entity() const
    return mpEllipse;
// This function uses the AcEdJig mechanism to create and
// drag an ellipse entity.  The creation criteria are
// slightly different from the AutoCAD command.  In this
// case, the user selects an ellipse center point and
// drags to visually select the major and minor axes
// lengths.  This sample is somewhat limited; if the
// minor axis ends up longer than the major axis, then the
// ellipse will just be round because the radius ratio
// cannot be greater than 1.0.
void
createEllipse()
    // First, have the user select the ellipse center point.
    // We don't use the jig for this because there is
    // nothing to see yet.
    AcGePoint3d tempPt;
    struct resbuf rbFrom, rbTo;
    acedGetPoint(NULL, "\nEllipse center point: ",
        asDblArray(tempPt));
    // The point we just got is in UCS coordinates, but
    // AcDbEllipse works in WCS, so convert the point.
    rbFrom.restype = RTSHORT;
    rbFrom.resval.rint = 1; // from UCS
    rbTo.restype = RTSHORT;
    rbTo.resval.rint = 0; // to WCS
    acedTrans(asDblArray(tempPt), &rbFrom, &rbTo,
        Adesk::kFalse, asDblArray(tempPt));
    // Now you need to get the current UCS z-Axis to be used
    // as the normal vector for the ellipse.
    AcGeVector3d x =
        acdbHostApplicationServices()->workingDatabase()->ucsxdir();
    AcGeVector3d y =
        acdbHostApplicationServices()->workingDatabase()->ucsydir();
    AcGeVector3d normalVec = x.crossProduct(y);
    normalVec.normalize();
    // Create an AsdkEllipseJig object passing in the
    // center point just selected by the user and the normal
    // vector just calculated.
    AsdkEllipseJig *pJig
        = new AsdkEllipseJig(tempPt, normalVec);
    // Now start up the jig to interactively get the major
    // and minor axes lengths.
    pJig->doIt();
    // Now delete the jig object, since it is no longer needed.
    delete pJig;
void
initApp()
    acedRegCmds->addCommand("ASDK_VISUAL_ELLIPSE",
        "ASDK_VELLIPSE", "VELLIPSE", ACRX_CMD_MODAL,
        createEllipse);
void
unloadApp()
    acedRegCmds->removeGroup("ASDK_VISUAL_ELLIPSE");
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
    switch (msg) {
    case AcRx::kInitAppMsg:
        acrxDynamicLinker->unlockApplication(appId);
        acrxDynamicLinker->registerAppMDIAware(appId);
        initApp();
        break;
    case AcRx::kUnloadAppMsg:
        unloadApp();
    return AcRx::kRetOK;
  1. 使用 AcEdJig
GMT+8, 2026-11-2 13:03
