AutoCAD 2024 开发者帮助
与其他实体相交
2024-5-18 19:12| 发布者: admin| 查看: 925| 评论: 0|原作者: admin|来自: AutoCAD
与其他实体相交
该函数有两种形式:intersectWith()
virtual  Acad::ErrorStatus
intersectWith(
    const AcDbEntity* ent,
    AcDb::Intersect intType,
    AcGePoint3dArray& points,
    int thisGsMarker = 0,
    int otherGsMarker = 0) const;
intersectWith(
    const AcGePlane& projPlane,
函数的第一种形式测试两个实体的简单交集。第二种形式计算投影平面上的交点。但是,这两个函数都返回实体本身的交点。若要实现自定义行为,请重写相应的函数。intersectWith()subIntersectWith()
使用 intersectWith() 函数的投影平面形式
  1. 将实体和参数实体投影到平面上。
  2. 在投影平面上测试相交的图元。
  3. 将交点投影回图元并返回它们。
自定义类重写函数的两种形式。AsdkPolysubIntersectWith()
 Acad::ErrorStatus
 AsdkPoly::subIntersectWith(
     int /*thisGsMarker*/,
     int /*otherGsMarker*/) const
     assertReadEnabled();
     Acad::ErrorStatus es = Acad::eOk;
     if (ent == NULL)
         return Acad::eNullEntityPointer;
     // The idea is to intersect each side of the polygon
     // with the given entity and return all the points.
     // For non-R12-entities, with
     // intersection methods defined, we call that method for
     // each of the sides of the polygon. For R12-entities,
     // we use the locally defined intersectors, since their
     // protocols are not implemented.
     if (ent->isKindOf(AcDbLine::desc())) {
         if ((es = intLine(this, AcDbLine::cast(ent),
             intType, NULL, points)) != Acad::eOk)
             return es;
     } else if (ent->isKindOf(AcDbArc::desc())) {
         if ((es = intArc(this, AcDbArc::cast(ent), intType,
             return es;
     } else if (ent->isKindOf(AcDbCircle::desc())) {
         if ((es = intCircle(this, AcDbCircle::cast(ent),
             return es;
     } else if (ent->isKindOf(AcDb2dPolyline::desc())) {
         if ((es = intPline(this, AcDb2dPolyline::cast(ent),
             return es;
     } else if (ent->isKindOf(AcDb3dPolyline::desc())) {
         if ((es = intPline(this, AcDb3dPolyline::cast(ent),
             return es;
     } else {
         AcGePoint3dArray vertexArray;
         if ((es = getVertices3d(vertexArray))
             != Acad::eOk)
             return es;
         if (intType == AcDb::kExtendArg
             || intType == AcDb::kExtendBoth)
             intType = AcDb::kExtendThis;
         AcDbLine *pAcadLine;
         for (int i = 0; i < vertexArray.length() - 1; i++) {
             pAcadLine = new AcDbLine();
             pAcadLine->setStartPoint(vertexArray[i]);
             pAcadLine->setEndPoint(vertexArray[i + 1]);
             pAcadLine->setNormal(normal());
             if ((es = ent->intersectWith(pAcadLine, intType,
                 delete pAcadLine;
                 return es;
             delete pAcadLine;
     return es;
 Acad::ErrorStatus
     if (ent == NULL)
             intType, &projPlane, points)) != Acad::eOk)
             return es;
             return es;
             return es;
             return es;
             return es;
     } else {
             != Acad::eOk)
             return es;
         int i;
         for (i = 0; i < vertexArray.length() - 1; i++) {
                 delete pAcadLine;
                 return es;
             delete pAcadLine;
         // All the points that we selected in this process are on
         // the other curve; we are dealing with apparent
         // intersection. If the other curve is 3D or is not
         // on the same plane as poly, the points are not on
         // poly.
         // In this case, we need to do some more work. Project the
         // points back onto the plane. They should lie on
         // the projected poly. Find points on real poly
         // corresponding to the projected points.
         AcGePoint3d projPt, planePt;
         AcGePoint3dArray pts;
         AcGeLine3d line;
         AcGePlane polyPlane;
         AcDb::Planarity plnrty;
         getPlane(polyPlane,plnrty);
         for (i = 0; i < points.length(); i++) {
             // Define a line starting from the projPt and
             // along the normal.  Intersect the polygon with
             // that line. Find all the points and pick the
             // one closest to the given point.
             projPt = points[i].orthoProject(projPlane);
             line.set(projPt, projPlane.normal());
             if ((es = intLine(this, line, pts))
                 != Acad::eOk)
                 return es;
             planePt = projPt.project(polyPlane,
             points[i] = pts[0];
             double length = (planePt - pts[0]).length();
             double length2;
             for (int j = 1; j < pts.length(); j++) {
                 if ((length2 = (planePt - pts[j]).length())
                     < length)
                     points[i] = pts[j];
                     length = length2;
     return es;
GMT+8, 2026-11-4 21:12
