实现对象捕捉点功能
如果希望自定义实体支持对象捕捉模式,则需要覆盖该函数。AutoCAD 调用以获取当前模式的相关捕捉点,然后调用该捕捉点以访问自定义图元的捕捉模式。如果不希望实体支持特定模式的捕捉点,则可以筛选出支持的捕捉模式,并返回其他模式;系统将提示用户再次选择。如果多个对象捕捉模式处于活动状态,则对每个对象捕捉模式调用一次此函数。subGetOsnapPoints()getOsnapPoints()subGetOsnapPoints()eOk 注意:交集对象捕捉模式的处理方式与 不同。它使用 ,而不是 。getOsnapPoints()AcDbEntity::intersectWith()getOsnapPoints()
下面显示了该类如何实现该函数:AsdkPolysubGetOsnapPoints() Acad::ErrorStatus
AsdkPoly::subGetOsnapPoints(
AcDb::OsnapMode osnapMode,
Adesk::GsMarker gsSelectionMark,
const AcGePoint3d& pickPoint,
const AcGePoint3d& lastPoint,
const AcGeMatrix3d& viewXform,
AcGePoint3dArray& snapPoints,
AcDbIntArray& /*geomIds*/) const
assertReadEnabled();
Acad::ErrorStatus es = Acad::eOk;
if (gsSelectionMark == 0)
return Acad::eOk;
if ( osnapMode != AcDb::kOsModeEnd
&& osnapMode != AcDb::kOsModeMid
&& osnapMode != AcDb::kOsModeNear
&& osnapMode != AcDb::kOsModePerp
&& osnapMode != AcDb::kOsModeCen
&& osnapMode != AcDb::kOsModeIns)
return Acad::eOk;
// First, check to see if the gsSelection marker is the
// text geometry. If so, handle center and insertion
// modes, then return. No need to go into perp, mid, etc.
AcGePoint3d center;
getCenter(center);
if (gsSelectionMark == (mNumSides + 1)) {
if (osnapMode == AcDb::kOsModeIns)
snapPoints.append(center);
else if (osnapMode == AcDb::kOsModeCen)
return es;
int startIndex = (int)(gsSelectionMark - 1);
AcGePoint3dArray vertexArray;
if ((es = getVertices3d(vertexArray)) != Acad::eOk) {
return es;
AcGeLineSeg3d lnsg(vertexArray[startIndex],
vertexArray[startIndex + 1]);
AcGePoint3d pt;
AcGeLine3d line, perpLine;
AcGeVector3d vec;
AcGeVector3d viewDir(viewXform(Z, 0), viewXform(Z, 1),
viewXform(Z, 2));
switch (osnapMode) {
case AcDb::kOsModeEnd:
snapPoints.append(vertexArray[startIndex]);
snapPoints.append(vertexArray[startIndex + 1]);
break;
case AcDb::kOsModeMid:
pt.set(
((vertexArray[startIndex])[X]
+ (vertexArray[startIndex + 1])[X]) * 0.5,
((vertexArray[startIndex])[Y]
+ (vertexArray[startIndex + 1])[Y]) * 0.5,
((vertexArray[startIndex])[Z]
+ (vertexArray[startIndex + 1])[Z]) * 0.5);
snapPoints.append(pt);
break;
case AcDb::kOsModeNear:
pt = lnsg.projClosestPointTo(pickPoint, viewDir);
break;
case AcDb::kOsModePerp:
// Create a semi-infinite line and find a point on it.
vec = vertexArray[startIndex + 1]
- vertexArray[startIndex];
vec.normalize();
line.set(vertexArray[startIndex], vec);
pt = line.closestPointTo(lastPoint);
break;
case AcDb::kOsModeCen:
break;
default:
return Acad::eOk;
return es;
父主题: |
GMT+8, 2026-10-23 20:10
