AutoCAD 2024 开发者帮助
源文件
2024-5-18 19:12| 发布者: admin| 查看: 700| 评论: 0|原作者: admin|来自: AutoCAD
源文件
下面的代码显示了新类的实现:AsdkMyClass
ACRX_DXF_DEFINE_MEMBERS(AsdkMyClass, AcDbObject,
    AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent, 0,
    ASDKMYCLASS, SAMP2);
// Gets the value of the integer data member.
Acad::ErrorStatus
AsdkMyClass::getData(Adesk::Int16& val)
    // Tells AutoCAD a read operation is taking place.
    assertReadEnabled();
    val = mIntval;
    return Acad::eOk;
// Sets the value of the integer data member.
Acad::ErrorStatus
AsdkMyClass::setData(Adesk::Int16 val)
    // Triggers openedForModify notification.
    assertWriteEnabled();
    mIntval = val;
    return Acad::eOk;
// Files data in from a DWG file.
Acad::ErrorStatus
AsdkMyClass::dwgInFields(AcDbDwgFiler* pFiler)
    AcDbObject::dwgInFields(pFiler);
    // For wblock filing we wrote out our owner as a hard
    // pointer ID so now we need to read it in to keep things
    // in sync.
    if (pFiler->filerType() == AcDb::kWblockCloneFiler) {
        AcDbHardPointerId id;
        pFiler->readItem(&id);
    pFiler->readItem(&mIntval);
    return pFiler->filerStatus();
// Files data out to a DWG file.
Acad::ErrorStatus
AsdkMyClass::dwgOutFields(AcDbDwgFiler* pFiler) const
    AcDbObject::dwgOutFields(pFiler);
    // Since objects of this class will be in the Named
    // Objects Dictionary tree and may be hard referenced
    // by some other object, to support wblock we need to
    // file out our owner as a hard pointer ID so that it
    // will be added to the list of objects to be wblocked.
        pFiler->writeHardPointerId((AcDbHardPointerId)ownerId());
    pFiler->writeItem(mIntval);
// Files data in from a DXF file.
Acad::ErrorStatus
AsdkMyClass::dxfInFields(AcDbDxfFiler* pFiler)
    Acad::ErrorStatus es;
    if ((es = AcDbObject::dxfInFields(pFiler))
        != Acad::eOk)
        return es;
    // Check if we're at the right subclass getData marker.
    if (!pFiler->atSubclassData("AsdkMyClass")) {
        return Acad::eBadDxfSequence;
    struct resbuf inbuf;
    while (es == Acad::eOk) {
        if ((es = pFiler->readItem(&inbuf)) == Acad::eOk) {
            if (inbuf.restype == AcDb::kDxfInt16) {
                mIntval = inbuf.resval.rint;
// Files data out to a DXF file.
Acad::ErrorStatus
AsdkMyClass::dxfOutFields(AcDbDxfFiler* pFiler) const
    AcDbObject::dxfOutFields(pFiler);
    pFiler->writeItem(AcDb::kDxfSubclass, "AsdkMyClass");
    pFiler->writeItem(AcDb::kDxfInt16, mIntval);
// This function creates two objects of class AsdkMyClass.
// It fills them in with the integers 1 and 2, and then adds
// them to the dictionary associated with the key ASDK_DICT.
// If this dictionary doesn't exist, it is created and added
// to the named object dictionary.
void
createDictionary()
    AcDbDictionary *pNamedobj;
    acdbHostApplicationServices()->workingDatabase()->
        getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite);
    // Check to see if the dictionary we want to create is
    // already present. If not, create it and add
    // it to the named object dictionary.
    AcDbDictionary *pDict;
    if (pNamedobj->getAt("ASDK_DICT", (AcDbObject*&) pDict,
        AcDb::kForWrite) == Acad::eKeyNotFound)
        pDict = new AcDbDictionary;
        AcDbObjectId DictId;
        pNamedobj->setAt("ASDK_DICT", pDict, DictId);
    pNamedobj->close();
    if (pDict) {
        // Create new objects to add to the new dictionary,
        // add them, then close them.
        AsdkMyClass *pObj1 = new AsdkMyClass(1);
        AsdkMyClass *pObj2 = new AsdkMyClass(2);
        AcDbObjectId rId1, rId2;
        pDict->setAt("OBJ1", pObj1, rId1);
        pDict->setAt("OBJ2", pObj2, rId2);
        pObj1->close();
        pObj2->close();
        pDict->close();
// Opens the dictionary associated with the key ASDK_DICT
// and iterates through all its entries, printing out the
// integer data value in each entry.
void
iterateDictionary()
        ->getNamedObjectsDictionary(pNamedobj, AcDb::kForRead);
    // Get a pointer to the ASDK_DICT dictionary.
    pNamedobj->getAt("ASDK_DICT", (AcDbObject*&)pDict,
        AcDb::kForRead);
    pNamedobj->close();
    // Get an iterator for the ASDK_DICT dictionary.
    AcDbDictionaryIterator* pDictIter= pDict->newIterator();
    AsdkMyClass *pMyCl;
    Adesk::Int16 val;
    for (; !pDictIter->done(); pDictIter->next()) {
        // Get the current record, open it for read, and
        // print its data.
        pDictIter->getObject((AcDbObject*&)pMyCl,
            AcDb::kForRead);
        pMyCl->getData(val);
        pMyCl->close();
        acutPrintf("\nintval is:  %d", val);
    delete pDictIter;
    pDict->close();
// The initialization function called from the acrxEntryPoint()
// function during the kInitAppMsg case is used to add commands
// to the command stack and to add classes to the ACRX class
// hierarchy.
void
initApp()
    acedRegCmds->addCommand("ASDK_DICTIONARY_COMMANDS",
        "ASDK_CREATE", "CREATE", ACRX_CMD_MODAL,
        createDictionary);
        "ASDK_ITERATE", "ITERATE", ACRX_CMD_MODAL,
        iterateDictionary);
    AsdkMyClass::rxInit();
    acrxBuildClassHierarchy();
// The cleanup function called from the acrxEntryPoint() function
// during the kUnloadAppMsg case removes this application's
// command set from the command stack and removes this application's
// custom classes from the ACRX runtime class hierarchy.
void
unloadApp()
    acedRegCmds->removeGroup("ASDK_DICTIONARY_COMMANDS");
    // Remove the AsdkMyClass class from the ACRX runtime
    // class hierarchy.  If this is done while the database is
    // still active, it should cause all objects of class
    // AsdkMyClass to be turned into proxies.
    deleteAcRxClass(AsdkMyClass::desc());
GMT+8, 2026-9-8 18:33
