AutoCAD 2024 开发者帮助
ObjectARX 扩展字典示例
2024-5-18 19:11| 发布者: admin| 查看: 797| 评论: 0|原作者: admin|来自: AutoCAD
ObjectARX 扩展字典示例
下面的示例演示如何实例化 xrecord 并将其添加到命名对象字典中的扩展字典中:
void
createXrecord()
    AcDbXrecord *pXrec = new AcDbXrecord;
    AcDbObject *pObj;
    AcDbObjectId dictObjId, xrecObjId;
    AcDbDictionary* pDict;
    pObj = selectObject(AcDb::kForWrite);
    if (pObj == NULL) {
        return;
    // Try to create an extension dictionary for this
    // object.  If the extension dictionary already exists,
    // this will be a no-op.
    pObj->createExtensionDictionary();
    // Get the object ID of the extension dictionary for the
    // selected object.
    dictObjId = pObj->extensionDictionary();
    pObj->close();
    // Open the extension dictionary and add the new
    // xrecord to it.
    acdbOpenObject(pDict, dictObjId, AcDb::kForWrite);
    pDict->setAt("ASDK_XREC1", pXrec, xrecObjId);
    pDict->close();
    // Create a resbuf list to add to the xrecord.
    struct resbuf* head;
    ads_point testpt = {1.0, 2.0, 0.0};
    head = acutBuildList(AcDb::kDxfText,
        "This is a test Xrecord list",
        AcDb::kDxfXCoord, testpt,
        AcDb::kDxfReal, 3.14159,
        AcDb::kDxfAngle, 3.14159,
        AcDb::kDxfColor, 1,
        AcDb::kDxfInt16, 180,
        0);
    // Add the data list to the xrecord.  Notice that this
    // member function takes a reference to a resbuf NOT a
    // pointer to a resbuf, so you must dereference the
    // pointer before sending it.
    pXrec->setFromRbChain(*head);
    pXrec->close();
    acutRelRb(head);
// The listXrecord() function gets the xrecord associated with the
// key "ASDK_XREC1" and lists out its contents by passing the resbuf
// list to the function printList().
void
listXrecord()
    AcDbObject *pObj;
    AcDbXrecord *pXrec;
    AcDbObjectId dictObjId;
    AcDbDictionary *pDict;
    pObj = selectObject(AcDb::kForRead);
    if (pObj == NULL) {
        return;
    // Get the object ID of the object's extension dictionary.
    pObj->close();
    // Open the extension dictionary and get the xrecord
    // associated with the key ASDK_XREC1.
    acdbOpenObject(pDict, dictObjId, AcDb::kForRead);
    pDict->getAt("ASDK_XREC1", (AcDbObject*&)pXrec,
        AcDb::kForRead);
    pDict->close();
    // Get the xrecord's data list and then close the xrecord.
    struct resbuf *pRbList;
    pXrec->rbChain(&pRbList);
    pXrec->close();
    printList(pRbList);
    acutRelRb(pRbList);
  1. 扩展字典
GMT+8, 2026-10-23 00:19
