代码示例:编写需求加载键
以下示例(来自 ObjectARX SDK polysamp 示例程序)演示了如何为注册组和命令的 ObjectARX 应用程序编写需求加载密钥: void updateRegistry()
// Fill the AppInfo structure with our demand loading details.
AcadAppInfo appInfo;
appInfo.setAppName("AsdkPolyCAD"); // Application name
appInfo.setModuleName(acedGetAppName());// Module path
appInfo.setAppDesc("AsdkPolyCAD"); // Description
appInfo.setLoadReason(// Specify when we want these to load
AcadApp::LoadReasons(
AcadApp::kOnCommandInvocation |
AcadApp::kOnLoadRequest));
// Write the appInfo to the registry.
appInfo.writeToRegistry();
// Write the group name.
appInfo.writeGroupNameToRegistry("ASDK_POLYGON");
// Write out all our commands (Global,Local).
appInfo.writeCommandNameToRegistry("ASDK_POLY","POLY");
appInfo.writeCommandNameToRegistry("ASDK_DRAGPOLY","DRAGPOLY");
appInfo.writeCommandNameToRegistry("ASDK_POLYEDIT","POLYEDIT");
appInfo.writeCommandNameToRegistry("ASDK_TRANSACT","TRANSACT");
appInfo.writeCommandNameToRegistry("ASDK_HILITPOLY","HILITPOLY");
appInfo.writeCommandNameToRegistry("ASDK_HILITSOLID","HILITSOLID");
appInfo.writeCommandNameToRegistry("ASDK_CREATEINSERT","CREATEINSERT");
appInfo.writeCommandNameToRegistry("ASDK_HILITINSERT","HILITINSERT");
注意:Object Enabler 使用 ObjectARX 注册表格式的缩写版本。有关详细信息,请参阅“Object Enabler”中的“Registering Object Enabler for Demand Loading”部分。
父主题: |
GMT+8, 2026-10-23 03:10
