AutoCAD 2024 开发者帮助
示例应用
2024-5-18 19:11| 发布者: admin| 查看: 708| 评论: 0|原作者: admin|来自: AutoCAD
示例应用
下面的示例应用程序实现在加载和卸载应用程序时调用的函数。其初始化功能向 AutoCAD 添加了两个新命令:CREATE 和 ITERATE。
它还初始化新类,并使用该函数将其添加到 ObjectARX 层次结构中。(在自定义对象类示例中进行了介绍。AsdkMyClassacrxBuildClassHierarchy()AsdkMyClass
// The initialization function called from the acrxEntryPoint()
// function during the kInitAppMsg case is used to add commands
// to the command stack and to add classes to the ACRX class
// hierarchy.
void
initApp()
    acedRegCmds->addCommand("ASDK_DICTIONARY_COMMANDS",
        "ASDK_CREATE", "CREATE", ACRX_CMD_MODAL,
        createDictionary);
        "ASDK_ITERATE", "ITERATE", ACRX_CMD_MODAL,
        iterateDictionary);
    AsdkMyClass::rxInit();
    acrxBuildClassHierarchy();
// The cleanup function called from the acrxEntryPoint()
// function during the kUnloadAppMsg case removes this application's
// command set from the command stack and removes this application's
// custom classes from the ACRX runtime class hierarchy.
void
unloadApp()
    acedRegCmds->removeGroup("ASDK_DICTIONARY_COMMANDS");
    // Remove the AsdkMyClass class from the ACRX runtime
    // class hierarchy. If this is done while the database is
    // still active, it should cause all objects of class
    // AsdkMyClass to be turned into proxies.
    deleteAcRxClass(AsdkMyClass::desc());
GMT+8, 2026-9-6 07:33
