AutoCAD 2024 开发者帮助
DefinedSize Property (ActiveX/CAO)
2024-5-18 19:11| 发布者: admin| 查看: 541| 评论: 0|原作者: admin|来自: AutoCAD
Specifies the maximum field width of the specified object.
VBA / VB.NET
object.DefinedSize
Type: KeyDescription
The object or objects this property applies to.
DefinedSize
Type: Long
The maximum field width allowed for the KeyDescription object.
GMT+8, 2026-10-23 08:15
