AutoCAD 2024 开发者帮助
DataSource Property (ActiveX/CAO)
2024-5-18 19:11| 发布者: admin| 查看: 738| 评论: 0|原作者: admin|来自: AutoCAD
Holds the data source name value.
VBA / VB.NET
object.DataSource
Type: LabelTemplate, LinkTemplate, or Query
The object or objects this property applies to.
数据源
Type: String
Specifies the name of the data source.
GMT+8, 2026-10-22 07:11
