AutoCAD 2024 开发者帮助
IncludeNestedOverlayXrefDwg 属性 (ActiveX/ATO)
2024-5-18 19:11| 发布者: admin| 查看: 820| 评论: 0|原作者: admin|来自: AutoCAD
指定附着到具有叠加附件类型的图形文件的外部参照是否包含在传递包中。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VBA/VB.NET/C#:
object.includeNestedOverlayXrefDwg
类型:TransmittalInfo
此属性应用于的对象。
只读:
类型:
  • 0 (False) - 从传递包中排除附件类型为叠加的嵌套外部参照
  • 1 (True) - 具有叠加附件类型的嵌套外部参照包含在传递包中
发行信息
释放:AutoCAD 2010 及更高版本
VB.NET:
' Custom function used to setup a TransmittalInfo object
Private Shared Function TransInfo(ti As TransmittalInfo, destination As String) _
    As TransmittalInfo
    ' Specify the folder that the files should be copied to
    If System.IO.Directory.Exists(destination) = False Then
        System.IO.Directory.CreateDirectory(destination)
    End If
    ' Assign the location which the transmittal package should be stored
    ti.destinationRoot = destination
    ' Maintain sub directories (0 - False, 1 - True)
    ti.preserveSubdirs = vbTrue
    ' Maintain folder paths
    ' ti.organizedFolder = 0 and ti.preserveSubdirs = 0 -
    '             All files are placed in a single folder which is specified
    '             by the destinationRoot property
    ' ti.organizedFolder = 1 and ti.preserveSubdirs = 0 -
    '             Files are placed in a single folder, but maintain one level
    '             of subdirectory strcuture
    ' ti.organizedFolder = 0 and ti.preserveSubdirs = 1 -
    '             Folder structure is maintained, but the paths for
    '             reference files are not
    ' ti.organizedFolder = 1 and ti.preserveSubdirs = 1 -
    '             Folder structure and reference paths are maintained
    ti.organizedFolder = vbTrue
    ' Change referenced files to use relative paths (0 - False, 1 - True)
    ti.dataLinkRelativePath = vbTrue
    ti.DGNUnderlayRelativePath = vbTrue
    ti.DWFUnderlayRelativePath = vbTrue
    ti.imageRelativePath = vbTrue
    ti.PDFUnderlayRelativePath = vbTrue
    ti.xrefRelativePath = vbTrue
    ' Set the default drawing file format for all DWG, DWT, and DWS files
    ' SaveDwgFormat.eAutoCAD14 - AutoCAD R14
    ' SaveDwgFormat.eAutoCAD2000 - AutoCAD 2000
    ' SaveDwgFormat.eAutoCADR18 - AutoCAD 2004
    ' SaveDwgFormat.eAutoCADR21 - AutoCAD 2007
    ' SaveDwgFormat.eAutoCADR24 - AutoCAD 2010
    ' SaveDwgFormat.eAutoCADR27 - AutoCAD 2013
    ' SaveDwgFormat.eAutoCADR32 - AutoCAD 2018
    ' SaveDwgFormat.eNoConversion - Keep current format
    ti.saveVersion = SaveDwgFormat.eNoConversion
    ' Maintain visual fidelity (SAVEFIDELITY system variable)
    ' 0 - Saved without visual fidelity
    ' 1 - Annotation objects assigned annotative scales are saved to
    '     separate layers for each scale used.
    '     Only affects drawings when saving to AutoCAD 2007 or earlier file formats.
    ti.visualFidelity = vbTrue
    ' Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True)
    ti.includeXrefDwg = vbTrue
    ti.includeUnloadedReferences = vbTrue
    ti.includeUnloadedXrefDwg = vbTrue
    ti.includeNestedOverlayXrefDwg = vbTrue
    ' Bind xrefs attached to a drawing (0 - False, 1 - True)
    ' BindType.eBind - Use the Bind type to bind the xrefs
    ' BindType.eInsert - Use the Insert type to bind the xrefs
    ti.BindType = BindType.eInsert
    ' Remove paths from xrefs (0 - False, 1 - True)
    ti.depathXrefs = vbTrue
    ' Include images, underlays, and datalink file (0 - False, 1 - True)
    ti.includeImageFile = vbTrue
    ti.includeDGNUnderlay = vbTrue
    ti.includeDWFUnderlay = vbTrue
    ti.includePDFUnderlay = vbTrue
    ti.includeDataLinkFile = vbTrue
    ' Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True)
    ti.includeFontFile = vbTrue
    ' Reset plotters for layouts in the drawings to None,
    ' and include plot style (CTB/STB) files (0 - False, 1 - True)
    ti.resetPlotter = vbFalse
    ti.includePlotFile = vbTrue
    ' Specify where the plot files are located so the API can resolve the file
    ' paths (used when includePlotFile = vbTrue or 1)
    ti.plotConfigFilePath = Environment.GetEnvironmentVariable("UserProfile") + _
             "\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters"
    ti.plotStyleTablePath = Environment.GetEnvironmentVariable("UserProfile") + _
             "\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters\Plot Styles"
    ' Get the photometric Web and material files used by lights
    ' and 3D objects for rendering (0 - False, 1 - True)
    ti.includePhotometricWebFile = vbTrue
    ti.includeMaterialTextureFile = vbTrue
    ' Purge unused named objects for all drawing files in the
    ' Transmittal(Package(0 - False, 1 - True))
    ti.purgeDatabase = vbFalse
    Return ti
End Function
C#:
// Custom function used to setup a TransmittalInfo object
private static TransmittalInfo TransInfo(TransmittalInfo ti, string destination)
    // Specify the folder that the files should be copied to
    if (System.IO.Directory.Exists(destination) == false)
        System.IO.Directory.CreateDirectory(destination);
    // Assign the location which the transmittal package should be stored
    ti.destinationRoot = destination;
    // Maintain sub directories (0 - False, 1 - True)
    ti.preserveSubdirs = 1;
    ti.organizedFolder = 1;
    // Change referenced files to use relative paths (0 - False, 1 - True)
    ti.dataLinkRelativePath = 1;
    ti.DGNUnderlayRelativePath = 1;
    ti.DWFUnderlayRelativePath = 1;
    ti.imageRelativePath = 1;
    ti.PDFUnderlayRelativePath = 1;
    ti.xrefRelativePath = 1;
    /* Set the default drawing file format for all DWG, DWT, and DWS files
    ti.saveVersion = SaveDwgFormat.eNoConversion;
    ti.visualFidelity = 1;
    // Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True)
    ti.includeXrefDwg = 1;
    ti.includeUnloadedReferences = 1;
    ti.includeUnloadedXrefDwg = 1;
    ti.includeNestedOverlayXrefDwg = 1;
    ti.BindType = BindType.eInsert;
    // Remove paths from xrefs (0 - False, 1 - True)
    ti.depathXrefs = 1;
    // Include images, underlays, and datalink file (0 - False, 1 - True)
    ti.includeImageFile = 1;
    ti.includeDGNUnderlay = 1;
    ti.includeDWFUnderlay = 1;
    ti.includePDFUnderlay = 1;
    ti.includeDataLinkFile = 1;
    // Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True)
    ti.includeFontFile = 1;
    // Reset plotters for layouts in the drawings to None,
    // and include plot style (CTB/STB) files (0 - False, 1 - True)
    ti.resetPlotter = 0;
    ti.includePlotFile = 1;
    // Specify where the plot files are located so the API can resolve the file
    // paths (used when includePlotFile = True or 1)
                            "\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters";
                            "\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters\\Plot Styles";
    // Get the photometric Web and material files used by lights
    // and 3D objects for rendering (0 - False, 1 - True)
    ti.includePhotometricWebFile = 1;
    ti.includeMaterialTextureFile = 1;
    // Purge unused named objects for all drawing files in the
    // Transmittal(Package(0 - False, 1 - True))
    ti.purgeDatabase = 0;
    return ti;
GMT+8, 2026-9-13 21:55
