EndFilesGraphCreation 方法 (ActiveX/ATO)
在将新节点添加到传递集的文件图时触发。 支持的平台:仅限 Windows 命名空间:传输塔利布 程序集: acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name
Implements TransmittalAddFileNotificationHandler
Public Sub endFilesGraphCreation(pTransmit As TRANSMITTALLib.TransmittalOperation) _
Implements TRANSMITTALLib.ITransmittalAddFileNotificationHandler.endFilesGraphCreation
End Class
C#: internal class custom_class_name : TransmittalAddFileNotificationHandler
public void endFilesGraphCreation(TRANSMITTALLib.TransmittalOperation pTransmit)
返回值 (RetVal)无返回值。 言论没有其他评论。 发行信息释放:AutoCAD 2004 及更高版本 例子VB.NET: ' Custom class used to monitor files being added to the transmittal package
Friend Class MyTransFileNotifier
Implements TRANSMITTALLib. _
Application.DocumentManager.MdiActiveDocument.Editor. _
WriteMessage(Environment.NewLine + "File graph creation ended.")
End Class
C#: // Custom class used to monitor files being added to the transmittal package
internal class MyTransFileNotifier : TransmittalAddFileNotificationHandler
WriteMessage(Environment.NewLine + "File graph creation ended.");
相关参考 |
GMT+8, 2026-11-4 22:06
