AutoCAD 2024 开发者帮助
AddSheetSelset 方法 (ActiveX/ATO)
2024-5-18 19:11| 发布者: admin| 查看: 723| 评论: 0|原作者: admin|来自: AutoCAD
将图纸集选区中的图形文件添加到传递集。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
object.addSheetSelset pISheetSelset, includeSSFiles
C#:
object.addSheetSelset(pISheetSelset, includeSSFiles);
类型:TransmittalOperation 对象
此方法应用到的对象。
pISheetSelset
访问:仅输入
类型: AcSmSheetSelSet
对象在库中定义。AcSmSheetSelSetAcSmComponents
includeSS软件
访问:仅输入
类型:长
  • 0 (): 不包括 DST 文件引用的工作表集 (DST) 和支持文件False
  • 1 ():包括 DST 文件引用的工作表集 (DST) 和支持文件True
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2005 及更高版本
历史
  • 该界面已与 AutoCAD 2010 版库中的界面合并。ITransmittalOperation2ITransmittalOperation
  • 该方法是在 AutoCAD 2005 版本的库中引入的。addSheetSelsetITransmittalOperation2
VB.NET:
' Custom command to create a transmittal package from a sheet selection set in a sheet set
<CommandMethod("eTransmitDSTFile_SheetSelSet")> _
Public Shared Sub eTransmitDSTFile_SheetSelSet()
    Dim ti As TransmittalInfo = _
        TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
    ' Add a sheet selection set from a sheet set
    ' and the drawings contained in it
    ' Get a reference to the Sheet Set Manager object
    Dim sheetSetManager As IAcSmSheetSetMgr = New AcSmSheetSetMgr
    ' Open a Sheet Set file
    Dim sheetSetDatabase As AcSmDatabase = _
        sheetSetManager.OpenDatabase("C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", False)
    ' Get all the SheetSelSets in the sheet set
    Dim sheetSelSetEnum As IAcSmEnumSheetSelSet = _
        sheetSetDatabase.GetSheetSet().GetSheetSelSets().GetEnumerator()
    ' Get the first SheetSelSet
    Dim sheetSelSet As AcSmSheetSelSet = sheetSelSetEnum.Next()
    Dim sheetSelSetFound As AcSmSheetSelSet = Nothing
    ' Check to the see if it is the requested SheetSelSet,
    ' if not get the next and check
    While Not sheetSelSet Is Nothing
        If UCase(sheetSelSet.GetName()). _
                        Equals("ELEVATIONS") = True Then
            sheetSelSetFound = sheetSelSet
        End If
        sheetSelSet = sheetSelSetEnum.Next()
    End While
    ' Get the sheet set from the database and process it
    ' 0 - Do not include DST file or support files referenced
    '     by the DST file (templates, blocks, ...)
    ' 1 - Include DST file, all files referenced by the
    '     DST file, its sheets and references
    If Not sheetSelSetFound Is Nothing Then
        tro.addSheetSelset(sheetSelSetFound, 0)
    End If
    ' Close the sheet set
    sheetSetManager.Close(sheetSetDatabase)
    ' Create the transmittal package
    ' Files are copied and resaved to the path specified by the destinationRoot property
    ' and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage()
C#:
// Custom command to create a transmittal package from a sheet selection set in a sheet set
[CommandMethod("eTransmitDSTFile_SheetSelSet")]
public static void eTransmitDSTFile_SheetSelSet()
    TransmittalInfo ti =
        TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
    // Add a sheet set and the drawings referenced in it
    // Get a reference to the Sheet Set Manager object
    IAcSmSheetSetMgr sheetSetManager = new AcSmSheetSetMgr();
    // Open a sheet set (DST) file
    AcSmDatabase sheetSetDatabase =
        sheetSetManager.OpenDatabase("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst", false);
    // Get all the SheetSelSets in the sheet set
    IAcSmEnumSheetSelSet sheetSelSetEnum =
        sheetSetDatabase.GetSheetSet().GetSheetSelSets().GetEnumerator();
    // Get the first SheetSelSet
    AcSmSheetSelSet sheetSelSet = sheetSelSetEnum.Next();
    AcSmSheetSelSet sheetSelSetFound = null;
    // Check to the see if it is the requested SheetSelSet,
    // if not get the next and check
    while (sheetSelSet != null)
        if (sheetSelSet.GetName().ToUpper().Equals("ELEVATIONS") == true)
            sheetSelSetFound = sheetSelSet;
    // Get the sheet set from the database and process it
    // 0 - Do not include DST file or support files referenced
    //     by the DST file (templates, blocks, ...)
    // 1 - Include DST file, all files referenced by the
    //     DST file, its sheets and references
    if (sheetSelSet != null)
        tro.addSheetSelset(sheetSelSet, 1);
    // Close the sheet set
    sheetSetManager.Close(sheetSetDatabase);
    // Create the transmittal package
    // Files are copied and resaved to the path specified by the destinationRoot property
    // and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage();
GMT+8, 2026-10-23 05:20
