WindowChanged 事件 (ActiveX)
当应用程序或文档窗口发生更改时触发。 支持的平台:仅限 Windows 签名VBA: object.WindowChanged(WindowState) 言论在实现与应用程序或文档窗口一起跟踪的工具栏或无模式对话框时,此事件非常有用。VB 或 ObjectARX 应用程序可以使用 HWNDFrame 参数获取窗口的坐标,将这些坐标转换为屏幕坐标或父坐标,并使用此信息定位其他窗口。 显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_WindowChanged(ByVal WindowState As Long)
' This example intercepts a drawing WindowChanged event.
' This event is triggered when the window state of the
' current drawing window is changed.
' To trigger this example event: Change the window state of the drawing window
' For example: Minimize or maximize the drawing window
Dim CurrentState As String
' Use the "WindowState" variable to determine the new drawing window state
Select Case WindowState
Case acMin: CurrentState = "Minimized"
Case acMax: CurrentState = "Maximized"
Case acNorm: CurrentState = "Normal Size"
End Select
MsgBox "The drawing window is now: " & CurrentState
可视化 LISP: Not available |
GMT+8, 2026-10-31 05:28
