AutoCAD 2024 开发者帮助
SysVarChanged 事件 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 878| 评论: 0|原作者: admin|来自: AutoCAD
在系统变量的值发生更改时触发。
object.SysVarChanged(SysVarName, NewVal)
类型: 应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
SysVarName
类型:字符串;输入到处理程序
其值已更改的系统变量的名称。
纽瓦尔
类型:变体;输入到处理程序
系统变量的新值。
此事件表示尝试更改系统变量。它不表示实际值已更改。在某些情况下,可以设置系统变量而不导致其值更改。例如,如果 FILLMODE 为 0,并且有人尝试将其设置为 0,则即使调用对 FILLMODE 的值没有实际影响,您也会得到该系统变量的事件。
显示模式对话框时不会触发任何事件。
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example intializes the public variable (ACADApp) which will be used
    ' to intercept AcadApplication Events
    ' The VBA WithEvents statement makes it possible to intercept an generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will first need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we grab it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.24.3")
Private Sub ACADApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal As Variant)
    ' This example intercepts an Application SysVarChanged event.
    ' This event is triggered when the value of a system variable is changed.
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Change the value of a system variable in AutoCAD.
    '     For example: Type GRIDMODE on the command line and toggle the grid display on/off
    ' Use the "SysvarName" and "newVal" variables to determine which
    ' system variable has changed and its new value.
    MsgBox "The system variable " & SysvarName & " was just changed to: " & newVal
Not available
GMT+8, 2026-11-2 18:47
