AutoCAD 2024 开发者帮助
BeginPlot 事件 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 912| 评论: 0|原作者: admin|来自: AutoCAD
在AutoCAD收到打印图形的请求后立即触发。
object.BeginPlot(DrawingName)
类型:应用程序,文档
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序和文档。
绘图名称
类型:字符串;输入到处理程序
要发送到打印机的图形的名称。
显示模式对话框时不会触发任何事件。
Private Sub AcadDocument_BeginPlot(ByVal DrawingName As String)
    ' This example intercepts a drawing BeginPlot event.
    ' This event is triggered when a drawing receives a plot request.
    ' To trigger this example event: Plot an open drawing
    ' Use the "DrawingName" variable to determine which drawing is about to plot
    MsgBox "A drawing has just received a request to plot for: " & DrawingName
Not available
GMT+8, 2026-10-22 07:08
