AutoCAD 2024 开发者帮助
AppActivate 事件 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 839| 评论: 0|原作者: admin|来自: AutoCAD
在激活主应用程序窗口之前触发。
object.AppActivate()
类型: 应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
显示模式对话框时不会触发任何事件。
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example initializes the public variable (ACADApp), which will be used
    ' to intercept AcadApplication Events
    ' The VBA WithEvents statement makes it possible to intercept a generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we get it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.24.3")
Private Sub ACADApp_AppActivate()
    ' This example intercepts an Application AppActivate event.
    ' This event is triggered when the AutoCAD application receives focus
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Switch focus from AutoCAD to another Windows application
    '     and then back again.
      MsgBox "AutoCAD was just activated!"
Not available
GMT+8, 2026-10-23 04:20
