AutoCAD 2024 开发者帮助
Views 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 1008| 评论: 0|原作者: admin|来自: AutoCAD
Views 属性 (ActiveX)
获取文档的 Views 集合。
object.Views
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型: 视图
文档的集合。Views
Sub Example_Views()
    ' This example finds the current views collection and
    ' adds a new view to that collection.
    Dim viewColl As AcadViews
    Set viewColl = ThisDrawing.Views
    ' Create a view named "TEST" in the current drawing
    Dim viewObj As AcadView
    Set viewObj = viewColl.Add("TEST")
    MsgBox "A new view called " & viewObj.name & " has been added to the views collection.", vbInformation, "Views Example"
(defun c:Example_Views()
    ;; This example finds the current views collection and
    ;; adds a new view to that collection.
    (setq viewColl (vla-get-Views doc))
    ;; Create a view named "TEST" in the current drawing
    (setq viewObj (vla-Add viewColl "TEST"))
    (alert (strcat "A new view called " (vla-get-Name viewObj) " has been added to the views collection."))
GMT+8, 2026-10-23 04:19
