AutoCAD 2024 开发者帮助
UpperRightCorner 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 899| 评论: 0|原作者: admin|来自: AutoCAD
获取当前活动视口的右上角。
object.UpperRightCorner
类型:视口
此属性应用于的对象。
只读:是的
类型:变体(双精度的两个元素数组)
表示当前活动视口右上角的 2D 坐标。
and 属性表示视口在显示器上的图形位置。这些属性定义如下:LowerLeftCornerUpperRightCorner
视口 1— = (0, .5), = (.5, 1)LowerLeftCornerUpperRightCorner
视口 2— = (.5, .5), = (1, 1)LowerLeftCornerUpperRightCorner
视口 3— = (0, 0), = (.5, .5)LowerLeftCornerUpperRightCorner
视口 4— = (.5, 0), = (1, .5)LowerLeftCornerUpperRightCorner
Sub Example_UpperRightCorner()
    ' This example creates a new viewport and makes it active.
    ' Then it splits the viewport into 4 windows.
    ' It then takes finds the upper right corner of each of the
    ' windows.
    Dim newViewport As AcadViewport
    ' Create a new viewport and make it active
    Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
    ThisDrawing.ActiveViewport = newViewport
    ' Split the viewport in 4 windows
    newViewport.Split acViewport4
    ' Make the newly split viewport active
    ' Iterate through the viewports. For each viewport,
    ' make that viewport active and display the coordinates
    ' of the upper right corner.
    Dim entry As AcadViewport
    Dim UpperRight As Variant
    For Each entry In ThisDrawing.Viewports
        entry.GridOn = True
        ThisDrawing.ActiveViewport = entry
        UpperRight = entry.UpperRightCorner
        MsgBox "The upper right corner of this viewport is " & UpperRight(0) & ", " & UpperRight(1), , "UpperRightCorner Example"
        entry.GridOn = False
    Next
(defun c:Example_UpperRightCorner()
    ;; This example creates a new viewport and makes it active.
    ;; Then it splits the viewport into four windows.
    ;; It then finds the lower-left corner of each of the
    ;; windows.
    ;; Create a new viewport and make it active
    (setq newViewport (vla-Add (vla-get-Viewports doc) "TESTVIEWPORT"))
    (vla-put-ActiveViewport doc newViewport)
    ;; Split the viewport in four windows
    (vla-Split newViewport acViewport4)
    ;; Make the newly split viewport active
    ;; Iterate through the viewports. For each viewport,
    ;; make that viewport active and display the coordinates
    ;; of the upper right corner.
    (vlax-for entry (vla-get-Viewports doc)
        (vla-put-GridOn entry :vlax-true)
        (vla-put-ActiveViewport doc entry)
        (setq upperRight (vlax-safearray->list (vlax-variant-value (vla-get-UpperRightCorner entry))))
        (alert (strcat "The upper right corner of this viewport is " (rtos (nth 0 upperRight) 2) ", " (rtos (nth 1 upperRight) 2)))
        (vla-put-GridOn entry :vlax-false)
GMT+8, 2026-10-23 12:47
