AutoCAD 2024 开发者帮助
TextWinBackgrndColor 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 1054| 评论: 0|原作者: admin|来自: AutoCAD
指定文本窗口的背景色。
object.TextWinBackgrndColor
类型:首选项显示
此属性应用于的对象。
只读:不
类型:OLE_COLOR(常量)
  • vbBlack
  • vbRed
  • vbYellow
  • vbGreen
  • vbCyan
  • vbBlue
  • vbMagenta
  • vbWhite
此属性的默认颜色是 Windows 标准窗口颜色。
Sub Example_TextWinBackgrndColor()
    ' TextWinBackgrndColor. It then changes the value, and finally
    Dim currTextWinBackgrndColor As OLE_COLOR
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current TextWinBackgrndColor value
    currTextWinBackgrndColor = preferences.Display.TextWinBackgrndColor
    MsgBox "The current value for TextWinBackgrndColor is " _
           & preferences.Display.TextWinBackgrndColor, vbInformation, "TextWinBackgrndColor Example"
    ' Change the value for TextWinBackgrndColor
    preferences.Display.TextWinBackgrndColor = vbBlue
    MsgBox "The new value for TextWinBackgrndColor is " _
    ' Reset TextWinBackgrndColor to its original value
    preferences.Display.TextWinBackgrndColor = currTextWinBackgrndColor
    MsgBox "The TextWinBackgrndColor value is reset to " _
(defun c:Example_TextWinBackgrndColor()
    ;; TextWinBackgrndColor. It then changes the value, and finally
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    ;; Retrieve the current TextWinBackgrndColor value
    (setq currTextWinBackgrndColor (vlax-variant-change-type (vla-get-TextWinBackgrndColor ACADPref) vlax-vbLong))
    (alert (strcat "The current value for TextWinBackgrndColor is " (itoa (vlax-variant-value currTextWinBackgrndColor))))
    ;; Change the value for TextWinBackgrndColor
    (vla-put-TextWinBackgrndColor ACADPref (vlax-make-variant acBlue 19))
    (setq newValue (vlax-variant-change-type (vla-get-TextWinBackgrndColor ACADPref) vlax-vbLong))
    (alert (strcat "The new value for TextWinBackgrndColor is " (itoa (vlax-variant-value newValue))))
    ;; Reset TextWinBackgrndColor to its original value
    (vla-put-TextWinBackgrndColor ACADPref (vlax-variant-change-type currTextWinBackgrndColor 19))
    (alert (strcat "The TextWinBackgrndColor value is reset to " (itoa (vlax-variant-value currTextWinBackgrndColor))))
GMT+8, 2026-11-19 17:08
