AutoCAD 2024 开发者帮助
TextStyle 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 995| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸或公差文本的文本样式。
object.TextStyle
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated、MLeaderStyle、Tolerance
此属性应用于的对象。
只读:不
类型:字符串
维度值的样式。
此属性的初始值为 STANDARD。
注意:此属性将覆盖给定维度的 DIMTXSTY 系统变量的值。
Sub Example_TextStyle()
    ' creates a new system text style.  The new text style is then assigned to
    ' the new dimension
    Dim dimObj As AcadDimAligned
    Dim newText As AcadTextStyle
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Create new text style
    Set newText = ThisDrawing.TextStyles.Add("MYSTYLE")
    newText.height = 0.5    ' Just set the height of the new style so we can differentiate
    ' Read and display the current text style for this dimension
    MsgBox "The text style is currently set to: " & dimObj.textStyle
    ' Change the text style to use the new style we created
    dimObj.textStyle = "MYSTYLE"
    MsgBox "The text style is now set to: " & dimObj.textStyle
(defun c:Example_TextStyle()
    ;; creates a new system text style.  The new text style is then assigned to
    ;; the new dimension
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    ;; Create new text style
    (setq newText (vla-Add (vla-get-TextStyles doc) "MYSTYLE"))
    (vla-put-Height newText 0.5)    ;; Just set the height of the new style so we can differentiate
    (vla-ZoomAll acadObj)
    ;; Read and display the current text style for this dimension
    (alert (strcat "The text style is currently set to: " (vla-get-TextStyle dimObj)))
    ;; Change the text style to use the new style we created
    (vla-put-TextStyle dimObj "MYSTYLE")
    (alert (strcat "The text style is now set to: " (vla-get-TextStyle dimObj)))
GMT+8, 2026-10-22 20:30
