AutoCAD 2024 开发者帮助
TextOutsideAlign 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 879| 评论: 0|原作者: admin|来自: AutoCAD
指定除纵坐标外的所有尺寸类型的扩展线外的尺寸文本的位置。
object.TextOutsideAlign
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:水平对齐文本。
  • False:将文本与尺寸线对齐。
此属性的初始值为 。True
注意:此属性将覆盖给定维度的 DIMTOH 系统变量的值。
Sub Example_TextOutsideAlign()
    ' allows the user to toggle the TextOutsideAlign value for the dimension
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5.5: point2(2) = 0
Toggle:
    Select Case MsgBox("Press OK to toggle the TextOutsideAlign value for this dimension", vbOKCancel)
        Case vbOK
            ' Toggle the TextOutsideAlign value for this dimension
            dimObj.TextOutsideAlign = Not (dimObj.TextOutsideAlign)
            dimObj.Update
            ThisDrawing.Regen acActiveViewport
            ' Read and display the new dimension TextOutsideAlign value
            MsgBox "TextOutsideAlign is currently set to: " & dimObj.TextOutsideAlign
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_TextOutsideAlign()
    ;; allows the user to toggle the TextOutsideAlign value for the dimension
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5.5 0)
    (vla-ZoomAll acadObj)
    ;; Toggle the TextOutsideAlign value for this dimension
    (vla-put-TextOutsideAlign dimObj (if (= (vla-get-TextOutsideAlign dimObj) :vlax-true) :vlax-false :vlax-true))
    (vla-Update dimObj)
    (vla-Regen doc acActiveViewport)
    ;; Read and display the new dimension TextOutsideAlign value
    (alert (strcat "TextOutsideAlign is currently set to: " (if (= (vla-get-TextOutsideAlign dimObj) :vlax-true) "True" "False")))
    (vla-Update dimObj)
GMT+8, 2026-11-1 08:07
