TextFrameDisplay 属性 (ActiveX)
使用文本框或文本对象切换多引线文本内容周围的框架显示,而不是显示文本本身。 支持的平台:仅限 Windows 属性值 - DatabasePreferences只读:不 类型:布尔
属性值 - GeoPositionMarker、MLeader只读:不 类型:布尔
言论此属性的初始值为 False。 DatabasePreferences:启用或禁用此选项后,必须使用该方法更新显示。Regen 注意:对象的此属性值存储在 QTEXTMODE 系统变量中。DatabasePreferences
例子VBA: Sub Example_TextFrameDisplay()
' TextFrameDisplay. It then changes the value, and finally
Dim currTextFrameDisplay As Boolean
' Retrieve the current TextFrameDisplay value
currTextFrameDisplay = ThisDrawing.Preferences.TextFrameDisplay
MsgBox "The current value for TextFrameDisplay is " & Preferences.TextFrameDisplay, vbInformation, "TextFrameDisplay Example"
' Change the value for TextFrameDisplay
ThisDrawing.Preferences.TextFrameDisplay = Not (currTextFrameDisplay)
MsgBox "The new value for TextFrameDisplay is " & Preferences.TextFrameDisplay, vbInformation, "TextFrameDisplay Example"
' Reset TextFrameDisplay to its original value
ThisDrawing.Preferences.TextFrameDisplay = currTextFrameDisplay
MsgBox "The TextFrameDisplay value is reset to " & Preferences.TextFrameDisplay, vbInformation, "TextFrameDisplay Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextFrameDisplay()
;; TextFrameDisplay. It then changes the value, and finally
(setq preferences (vla-get-Preferences doc))
;; Retrieve the current TextFrameDisplay value
(setq currTextFrameDisplay (vla-get-TextFrameDisplay preferences))
(alert (strcat "The current value for TextFrameDisplay is " (if (= currTextFrameDisplay :vlax-true) "True" "False")))
;; Change the value for TextFrameDisplay
(vla-put-TextFrameDisplay preferences (if (= currTextFrameDisplay :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The new value for TextFrameDisplay is " (if (= (vla-get-TextFrameDisplay preferences) :vlax-true) "True" "False")))
;; Reset TextFrameDisplay to its original value
(vla-put-TextFrameDisplay preferences currTextFrameDisplay)
(alert (strcat "The TextFrameDisplay value is reset to " (if (= (vla-get-TextFrameDisplay preferences) :vlax-true) "True" "False")))
GMT+8, 2026-10-23 08:15
