AutoCAD 2024 开发者帮助
TextFontSize 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 936| 评论: 0|原作者: admin|来自: AutoCAD
指定新文本的字体大小。
object.TextFontSize
类型:首选项显示
此属性应用于的对象。
只读:
类型:整数
新文本的字体大小。字体大小的限制由字体决定。
此属性的初始值为 10。
Sub Example_TextFontSize()
    ' TextFontSize. It then changes the value, and finally
    Dim currTextFontSize As Integer
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current TextFontSize value
    currTextFontSize = preferences.Display.TextFontSize
    MsgBox "The current value for TextFontSize is " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example"
    ' Change the value for TextFontSize
    preferences.Display.TextFontSize = 12
    MsgBox "The new value for TextFontSize is " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example"
    ' Reset TextFontSize to its original value
    preferences.Display.TextFontSize = currTextFontSize
    MsgBox "The TextFontSize value is reset to " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example"
(defun c:Example_TextFontSize()
    ;; TextFontSize. It then changes the value, and finally
    ;; Retrieve the current TextFontSize value
    (setq currTextFontSize (vla-get-TextFontSize (vla-get-Display preferences)))
    (alert (strcat "The current value for TextFontSize is " (itoa currTextFontSize)))
    ;; Change the value for TextFontSize
    (vla-put-TextFontSize (vla-get-Display preferences) 12)
    (alert (strcat "The new value for TextFontSize is " (itoa (vla-get-TextFontSize (vla-get-Display preferences)))))
    ;; Reset TextFontSize to its original value
    (vla-put-TextFontSize (vla-get-Display preferences) currTextFontSize)
    (alert (strcat "The TextFontSize value is reset to " (itoa (vla-get-TextFontSize (vla-get-Display preferences)))))
GMT+8, 2026-9-6 08:42
