AutoCAD 2024 开发者帮助
StyleSheet 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 957| 评论: 0|原作者: admin|来自: AutoCAD
指定布局或打印配置的样式表。
object.StyleSheet
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:字符串
样式表的名称。
Sub Example_StyleSheet()
    ' This example finds the name of the style sheet for the active layout
    Dim styleSheetName As String
    styleSheetName = ThisDrawing.ActiveLayout.StyleSheet
    If styleSheetName = "" Then
        MsgBox "There is no style sheet set for the active layout."
    Else
        MsgBox "The style sheet for the active layout is: " & styleSheetName
    End If
(defun c:Example_StyleSheet()
    ;; This example finds the name of the plot style for the active layout
    (setq styleSheetName (vla-get-StyleSheet (vla-get-ActiveLayout doc)))
    (if (= styleSheetName "")
        (alert "There is no style sheet set for the active layout.")
        (alert (strcat "The style sheet for the active layout is: " styleSheetName))
GMT+8, 2026-10-22 11:09
