AutoCAD 2024 开发者帮助
ShortCutMenuDisplay 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 770| 评论: 0|原作者: admin|来自: AutoCAD
控制在绘图区域中单击鼠标右键是否显示快捷菜单或发出 Enter 键。
object.ShortCutMenuDisplay
类型:PreferencesUser
此属性应用于的对象。
只读:
类型:布尔
  • True:在绘图区域中启用快捷菜单。
  • False:绘图区域中的快捷菜单被禁用。在绘图区域中单击鼠标右键将解释为 Enter。
此属性的初始值为 。True
当此属性设置为 时,可以使用对象中的属性自定义在绘图区域中单击鼠标右键的功能。TruePreferencesUser
注意:此属性的值存储在 SHORTCUTMENU 系统变量中。
Sub Example_ShortCutMenuDisplay()
    ' This example reads and toggles the preference value which controls
    ' whether right-clicking in the drawing area displays a shortcut menu
    ' or issues ENTER.
    Dim ACADPref As AcadPreferencesUser
    Dim newAction As String
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.User
    originalValue = ACADPref.ShortCutMenuDisplay
    newAction = IIf(originalValue, "displays the shortcut menu", "sends an ENTER keystroke to ACAD")
    MsgBox "Right-clicking the mouse CURRENTLY " & newAction, vbInformation
    ' Modify the AutoSnapMarker preference by toggling the value
    ACADPref.ShortCutMenuDisplay = Not (originalValue)
    newValue = ACADPref.ShortCutMenuDisplay
    newAction = IIf(newValue, "display the shortcut menu", "send an ENTER keystroke to ACAD")
    MsgBox "Right-clicking the mouse over the drawing WILL NOW " & newAction, vbInformation
(defun c:Example_ShortCutMenuDisplay()
    ;; This example reads and toggles the preference value which controls
    ;; whether right-clicking in the drawing area displays a shortcut menu
    ;; or issues ENTER.
    (setq originalValue (vla-get-ShortCutMenuDisplay (vla-get-User preferences)))
    (setq newAction (if (= originalValue :vlax-true) "displays the shortcut menu" "sends an ENTER keystroke to ACAD"))
    (alert (strcat "Right-clicking the mouse CURRENTLY " newAction))
    ;; Modify the AutoSnapMarker preference by toggling the value
    (vla-put-ShortCutMenuDisplay (vla-get-User preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-ShortCutMenuDisplay (vla-get-User preferences)))
    (setq newAction (if (= newValue :vlax-true) "displays the shortcut menu" "sends an ENTER keystroke to ACAD"))
    (alert (strcat "Right-clicking the mouse over the drawing WILL NOW " newAction))
GMT+8, 2026-9-6 11:01
