AutoCAD 2024 开发者帮助
SCMEditMode 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 1022| 评论: 0|原作者: admin|来自: AutoCAD
在“编辑”模式下确定绘图区域中的右键单击功能,这意味着选择了一个或多个对象,并且没有正在进行的命令。
object.SCMEditMode
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:枚举AcDrawingAreaSCMEdit
  • acEdRepeatLastCommand:禁用“编辑”快捷菜单。因此,如果选择了一个或多个对象且没有正在进行的命令,则在绘图区域中单击鼠标右键将发出 Enter,这将重复上次发出的命令。
  • acEdSCM:启用“编辑”快捷菜单。
此属性的初始值为 。acEdSCM
仅当属性设置为 True 时,才能设置此属性。ShortcutMenuDisplay
注意:此属性的值存储在 SHORTCUTMENU 系统变量中。
Sub Example_SCMEditMode()
    ' This example reads and modifies the SCMEditMode
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesUser
    Dim originalValue As Integer, newValue As Integer
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.User
    originalValue = ACADPref.SCMEditMode
    MsgBox "The SCMEditMode preference is set to: " & originalValue
    ' Modify the SCMEditMode preference by toggling the value
    ACADPref.SCMEditMode = acEdRepeatLastCommand
    MsgBox "The SCMEditMode preference has been set to: " & ACADPref.SCMEditMode
    ACADPref.SCMEditMode = originalValue
    MsgBox "The SCMEditMode preference was reset back to: " & originalValue
(defun c:Example_SCMEditMode()
    ;; This example reads and modifies the SCMEditMode
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-SCMEditMode (vla-get-User preferences)))
    (alert (strcat "The SCMEditMode preference is set to: " (itoa originalValue)))
    ;; Modify the SCMEditMode preference by toggling the value
    (vla-put-SCMEditMode (vla-get-User preferences) acEdRepeatLastCommand)
    (alert (strcat "The SCMEditMode preference has been set to: " (itoa (vla-get-SCMEditMode (vla-get-User preferences)))))
    (vla-put-SCMEditMode (vla-get-User preferences) originalValue)
    (alert (strcat "The SCMEditMode preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-23 01:17
