AutoCAD 2024 开发者帮助
RenderSmoothness 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 919| 评论: 0|原作者: admin|来自: AutoCAD
指定着色、渲染和隐藏的线删除对象的平滑度。
object.RenderSmoothness
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:双
有效范围为 0.01 到 10.0。
此属性的初始值为 0.5。若要提高性能,请在绘图时将此值设置为 1 或更小。
注意:此属性的值存储在 FACETRES 系统变量中。
Sub Example_RenderSmoothness()
    ' RenderSmoothness. It then changes the value, and finally
    Dim currRenderSmoothness As Double
    Dim newRenderSmoothness As Double
    ' Retrieve the current RenderSmoothness value
    currRenderSmoothness = ThisDrawing.preferences.RenderSmoothness
    MsgBox "The current value for RenderSmoothness is " & currRenderSmoothness, vbInformation, "RenderSmoothness Example"
    ' Change the value for RenderSmoothness
    newRenderSmoothness = 2.5
    ThisDrawing.preferences.RenderSmoothness = newRenderSmoothness
    MsgBox "The new value for RenderSmoothness is " & newRenderSmoothness, vbInformation, "RenderSmoothness Example"
    ' Reset RenderSmoothness to its original value
    ThisDrawing.preferences.RenderSmoothness = currRenderSmoothness
    MsgBox "The RenderSmoothness value is reset to " & currRenderSmoothness, vbInformation, "RenderSmoothness Example"
(defun c:Example_RenderSmoothness()
    ;; RenderSmoothness. It then changes the value, and finally
    (setq preferences (vla-get-Preferences doc))
    ;; Retrieve the current RenderSmoothness value
    (setq currRenderSmoothness (vla-get-RenderSmoothness preferences))
    (alert (strcat "The current value for RenderSmoothness is " (rtos currRenderSmoothness 2)))
    ;; Change the value for RenderSmoothness
    (setq newRenderSmoothness 2.5)
    (vla-put-RenderSmoothness preferences newRenderSmoothness)
    (alert (strcat "The new value for RenderSmoothness is " (rtos newRenderSmoothness 2)))
    ;; Reset RenderSmoothness to its original value
    (vla-put-RenderSmoothness preferences currRenderSmoothness)
    (alert (strcat "The RenderSmoothness value is reset to " (rtos currRenderSmoothness 2)))
GMT+8, 2026-10-22 13:04
