Red 属性 (ActiveX)
指定“真彩色”的红色分量。 支持的平台:仅限 Windows 属性值只读:是的 类型:长 的红色分量(从 0-255)为 。AcCmColor 言论没有其他评论。 例子VBA: Sub Example_Red()
' This example draws a line and returns the RGB values
Dim line As AcadLine
startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
Dim color As AcadAcCmColor
Set color = line.TrueColor
color.SetRGB 80, 100, 244
line.TrueColor = color
ZoomAll
Dim retcolor As AcadAcCmColor
Set retcolor = line.TrueColor
MsgBox "Red = " & retcolor.Red & vbLf & _
"Green = " & retcolor.Green & vbLf & _
"Blue = " & retcolor.Blue
可视化 LISP: (vl-load-com)
(defun c:Example_Red()
;; This example draws a line and returns the RGB values
doc (vla-get-ActiveDocument acadObj))
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
(setq modelSpace (vla-get-ModelSpace doc)
line (vla-AddLine modelSpace startPoint endPoint))
(setq color (vla-get-TrueColor line))
(vla-SetRGB color 80 100 244)
(vla-put-TrueColor line color)
(vla-ZoomAll acadObj)
(setq retcolor (vla-get-TrueColor line))
(alert (strcat "Red = " (itoa (vla-get-Red retcolor))
"\nGreen = " (itoa (vla-get-Green retcolor))
"\nBlue = " (itoa (vla-get-Blue retcolor))
GMT+8, 2026-10-23 00:30
