AutoCAD 2024 开发者帮助
Profiles 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 969| 评论: 0|原作者: admin|来自: AutoCAD
获取 PreferencesProfiles 对象。
object.Profiles
类型:首选项
此属性应用于的对象。
只读:是的
类型:PreferencesProfiles
获取对象。PreferencesProfiles
该对象保存存储在注册表中的“选项”对话框的“配置文件”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesProfilesDatabasePreferences
注意:虽然此特性在 AutoCAD LT for Windows 中可用,但由于产品不支持用户配置文件,因此对象不会公开任何特性和方法。PreferencesProfiles
Sub Example_Profiles()
    ' This example obtains a reference to the Profiles Preferences object
    ' from the Application Preferences object, and reads one of the Profiles
    ' preferences
    Dim ACADPref As AcadPreferencesProfiles
    ' Obtain a reference to the Profiles Preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Profiles
    MsgBox "You now have access to the properties and methods of the Profiles Preferences object!"
    MsgBox "The Profiles preference ActiveProfile is set to: " & ACADPref.ActiveProfile
(defun c:Example_Profiles()
    ;; This example obtains a reference to the Profiles Preferences object
    ;; from the Application Preferences object, and reads one of the Profiles
    ;; preferences
    ;; Obtain a reference to the Profiles Preferences object
    (alert "You now have access to the properties and methods of the Profiles Preferences object!")
    (alert (strcat "The Profiles preference ActiveProfile is set to: " (vla-get-ActiveProfile (vla-get-Profiles preferences))))
GMT+8, 2026-11-2 09:14
