AutoCAD 2024 开发者帮助
PlotViewportsFirst 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 722| 评论: 0|原作者: admin|来自: AutoCAD
指定是否首先打印图纸空间视口中的所有几何图形。
object.PlotViewportsFirst
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:首先绘制图纸空间视口中的几何图形,最后绘制图纸空间中的几何图形。
  • False:首先绘制纸张空间几何图形,最后绘制纸张空间视口中的几何图形。
Sub Example_PlotViewportsFirst()
    ' This example reads and modifies the PlotViewportsFirst
    ' Layout value.
    ' When finished, this example resets the  value back to
    ' its original value.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Boolean
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotViewportsFirst
    MsgBox "The PlotViewportsFirst value is set to: " & originalValue
    ' Modify the PlotViewportsFirst preference by toggling the value
    ACADLayout.PlotViewportsFirst = Not ACADLayout.PlotViewportsFirst
    MsgBox "The PlotViewportsFirst preference has been set to: " & ACADLayout.PlotViewportsFirst
    ACADLayout.PlotViewportsFirst = originalValue
    MsgBox "The PlotViewportsFirst preference was reset back to: " & originalValue
(defun c:Example_PlotViewportsFirst()
    ;; This example reads and modifies the PlotViewportsFirst
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-PlotViewportsFirst ACADLayout))
    (alert (strcat "The PlotViewportsFirst value is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PlotViewportsFirst preference by toggling the value
    (vla-put-PlotViewportsFirst ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PlotViewportsFirst ACADLayout))
    (alert (strcat "The PlotViewportsFirst preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    (vla-put-PlotViewportsFirst ACADLayout originalValue)
    (alert (strcat "The PlotViewportsFirst preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-22 13:22
