AutoCAD 2024 开发者帮助
PlotRotation 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 973| 评论: 0|原作者: admin|来自: AutoCAD
指定布局或打印配置的旋转角度。
object.PlotRotation
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:枚举acPlotRotation
  • ac0degrees
  • ac90degrees
  • ac180degrees
  • ac270degrees
旋转角度相对于物体 WCS 的 X 轴,从 Z 轴向下看原点时,正角逆时针方向。
在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen
Sub Example_PlotRotation()
    ' This example reads and modifies the PlotRotation
    ' Layout value.
    ' When finished, this example resets the  value back to
    ' its original value.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Integer
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotRotation
    MsgBox "The PlotRotation value is set to: " & originalValue
    ' Modify the PlotRotation preference by toggling the value
    ACADLayout.PlotRotation = ac180degrees
    MsgBox "The PlotRotation preference has been set to: " & ACADLayout.PlotRotation
    ACADLayout.PlotRotation = originalValue
    MsgBox "The PlotRotation preference was reset back to: " & originalValue
(defun c:Example_PlotRotation()
    ;; This example reads and modifies the PlotRotation
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-PlotRotation ACADLayout))
    (alert (strcat "The PlotRotation value is set to: " (itoa originalValue)))
    ;; Modify the PlotRotation preference by toggling the value
    (vla-put-PlotRotation ACADLayout ac180degrees)
    (alert (strcat "The PlotRotation preference has been set to: " (itoa (vla-get-PlotRotation ACADLayout))))
    (vla-put-PlotRotation ACADLayout originalValue)
    (alert (strcat "The PlotRotation preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-11-22 05:52
