AutoCAD 2024 开发者帮助
PickDrag 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 723| 评论: 0|原作者: admin|来自: AutoCAD
控制绘制选择窗口的方法。
object.PickDrag
类型:首选项选择
此属性应用于的对象。
只读:不
类型:布尔
  • True:通过拖动绘制选择窗口。单击一个角,按住指点设备上的拾取按钮,拖动并松开另一个角的按钮。
  • False:使用两个点绘制选择窗口。单击一个角的指针设备,然后单击另一个角。
此属性的初始值为 。False
注意:此属性的值存储在 PICKDRAG 系统变量中。
Sub Example_PickDrag()
    ' This example reads and modifies the preference value that controls
    ' the method of drawing a selection window.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.PickDrag
    MsgBox "The PickDrag preference is set to: " & originalValue
    ' Modify the PickDrag preference by toggling the value
    ACADPref.PickDrag = Not (ACADPref.PickDrag)
    newValue = ACADPref.PickDrag
    MsgBox "The PickDrag preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PickDrag = originalValue
    MsgBox "The PickDrag preference was reset back to: " & originalValue
(defun c:Example_PickDrag()
    ;; This example reads and modifies the preference value that controls
    ;; the method of drawing a selection window.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PickDrag (vla-get-Selection preferences)))
    (alert (strcat "The PickDrag preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PickDrag preference by toggling the value
    (vla-put-PickDrag (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PickDrag (vla-get-Selection preferences)))
    (alert (strcat "The PickDrag preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-PickDrag (vla-get-Selection preferences) originalValue)
    (alert (strcat "The PickDrag preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-23 09:20
