AutoCAD 2024 开发者帮助
PickBoxSize 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 923| 评论: 0|原作者: admin|来自: AutoCAD
指定对象选择目标的大小。
object.PickBoxSize
类型:首选项选择
此属性应用于的对象。
只读:不
类型:长
对象选择目标的高度(以像素为单位)。您可以输入一个介于 0 到 50 之间的值。
此属性的初始值为 3。
注意:此属性的值存储在 PICKBOX 系统变量中。
Sub Example_PickBoxSize()
    ' This example reads and modifies the preference value that controls
    ' the size of the object selection target.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.PickBoxSize
    MsgBox "The PickBoxSize preference is set to: " & originalValue
    ' Modify the PickBoxSize preference by setting it to 5
    ACADPref.PickBoxSize = 5
    newValue = ACADPref.PickBoxSize
    MsgBox "The PickBoxSize preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PickBoxSize = originalValue
    MsgBox "The PickBoxSize preference was reset back to: " & originalValue
(defun c:Example_PickBoxSize()
    ;; This example reads and modifies the preference value that controls
    ;; the size of the object selection target.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PickBoxSize (vla-get-Selection preferences)))
    (alert (strcat "The PickBoxSize preference is set to: " (itoa originalValue)))
    ;; Modify the PickBoxSize preference by setting it to 5
    (vla-put-PickBoxSize (vla-get-Selection preferences) 5)
    (setq newValue (vla-get-PickBoxSize (vla-get-Selection preferences)))
    (alert (strcat "The PickBoxSize preference has been set to: " (itoa newValue)))
    ;;         this preference in effect
    (vla-put-PickBoxSize (vla-get-Selection preferences) originalValue)
    (alert (strcat "The PickBoxSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-11-2 11:13
