AutoCAD 2024 开发者帮助
PageSetupOverridesTemplateFile 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 783| 评论: 0|原作者: admin|来自: AutoCAD
指定页面设置替代的默认模板。
object.PageSetupOverridesTemplateFile
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
包含页面设置覆盖的默认图形样板文件。
Sub Example_PageSetupOverridesTemplateFile()
    ' Note: Change the file path and name to a valid file on your system.
    Dim MyFiles As AcadPreferencesFiles
    Set MyFiles = AcadApplication.Preferences.Files
    MyFiles.PageSetupOverridesTemplateFile = "C:\MyTemplate.dwt"
(defun c:Example_PageSetupOverridesTemplateFile()
    ; Note: Change the file path and name to a valid file on your system.
    (setq MyFiles (vla-get-Files preferences))
    (vla-put-PageSetupOverridesTemplateFile MyFiles "C:\\MyTemplate.dwt")
GMT+8, 2026-10-23 11:04
