Output 属性 (ActiveX)
获取 PreferencesOutput 对象。 支持的平台:仅限 Windows 言论该对象保存存储在注册表中的“选项”对话框的“输出”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesOutputDatabasePreferences 例子VBA: Sub Example_Output()
' This example obtains a reference to the Output Preferences object
' from the Application Preferences object, and reads one of the Output
' preferences
Dim ACADPref As AcadPreferencesOutput
' Obtain a reference to the Output Preferences object
Set ACADPref = ThisDrawing.Application.preferences.Output
MsgBox "You now have access to the properties and methods of the Output Preferences object!"
MsgBox "The Output preference DefaultOutputDevice is set to: " & ACADPref.DefaultOutputDevice
可视化 LISP: (vl-load-com)
(defun c:Example_Output()
;; This example obtains a reference to the Output Preferences object
;; from the Application Preferences object, and reads one of the Output
;; preferences
;; Obtain a reference to the Output Preferences object
(alert (strcat "You now have access to the properties and methods of the Output Preferences object!"
"\nThe Output preference DefaultOutputDevice is set to: " (vla-get-DefaultOutputDevice (vla-get-Output preferences))))
GMT+8, 2026-10-23 12:47
