AutoCAD 2024 开发者帮助
OLELaunch 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 1000| 评论: 0|原作者: admin|来自: AutoCAD
确定在打印 OLE 对象时是否启动父应用程序。
object.OLELaunch
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:布尔
  • True:启动 OLE 对象的父应用程序以打印该对象。
  • False:OLE 对象是从 AutoCAD 打印的。
此属性的初始值为 。False
从父应用程序进行绘图可实现更高质量的绘图;但是,绘图的速度会降低。
注意:此属性的值存储在 OLESTARTUP 系统变量中。
Sub Example_OLELaunch()
    ' This example reads and modifies the preference value that controls
    ' whether to launch the parent application when plotting OLE objects.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadDatabasePreferences
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.preferences
    originalValue = ACADPref.OLELaunch
    MsgBox "The OLELaunch preference is set to: " & originalValue
    ' Modify the OLELaunch preference by toggling the value
    ACADPref.OLELaunch = Not (ACADPref.OLELaunch)
    newValue = ACADPref.OLELaunch
    MsgBox "The OLELaunch preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.OLELaunch = originalValue
    MsgBox "The OLELaunch preference was reset back to: " & originalValue
(defun c:Example_OLELaunch()
    ;; This example reads and modifies the preference value that controls
    ;; whether to launch the parent application when plotting OLE objects.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq preferences (vla-get-Preferences doc))
    (setq originalValue (vla-get-OLELaunch preferences))
    (alert (strcat "The OLELaunch preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the OLELaunch preference by toggling the value
    (vla-put-OLELaunch preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-OLELaunch preferences))
    (alert (strcat "The OLELaunch preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-OLELaunch preferences originalValue)
    (alert (strcat "The OLELaunch preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-10-23 08:23
