AutoCAD 2024 开发者帮助
ObliqueAngle 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 1028| 评论: 0|原作者: admin|来自: AutoCAD
指定对象的倾斜角度。
object.ObliqueAngle
类型:Attribute、AttributeReference、Shape、Text、TextStyle
此属性应用于的对象。
只读:不
类型:双
-85 到 +85 度范围内的弧度角度。正角表示向右倾斜;负值将添加 2*PI 以将其转换为正等价物。
斜角是物体远离其垂直轴的“倾斜角”。
Sub Example_ObliqueAngle()
    ' This example creates a text object in model space.
    ' It then changes the ObliqueAngle of the text object.
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Define the text object
    textString = "Hello, World."
    insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    ZoomAll
    MsgBox "The ObliqueAngle is " & textObj.ObliqueAngle, vbInformation, "ObliqueAngle Example"
    ' Change the value of the ObliqueAngle to 45 degrees (.707 radians)
    textObj.ObliqueAngle = 0.707
    ZoomAll
    MsgBox "The ObliqueAngle is set to " & textObj.ObliqueAngle, vbInformation, "ObliqueAngle Example"
(defun c:Example_ObliqueAngle()
    ;; This example creates a text object in model space.
    ;; It then changes the ObliqueAngle of the text object.
    ;; Define the text object
    (setq insertionPoint (vlax-3d-point 3 3 0)
          textString "Hello, World."
          height 0.5)
    ;; Create the text object in model space
    (setq textObj (vla-AddText modelSpace textString insertionPoint height))
    (vla-ZoomAll acadObj)
    (alert (strcat "The ObliqueAngle is " (rtos (vla-get-ObliqueAngle textObj) 2)))
    ;; Change the value of the ObliqueAngle to 45 degrees (.707 radians)
    (vla-put-ObliqueAngle textObj 0.707)
    (alert (strcat "The ObliqueAngle is set to " (rtos (vla-get-ObliqueAngle textObj) 2)))
GMT+8, 2026-10-23 05:19
