AutoCAD 2024 开发者帮助
NumberOfFitPoints 属性 (ActiveX)
2024-5-18 19:09| 发布者: admin| 查看: 775| 评论: 0|原作者: admin|来自: AutoCAD
获取样条曲线的拟合点数。
object.NumberOfFitPoints
类型:样条曲线
此属性应用于的对象。
只读:是的
类型:整数
样条曲线的拟合点数。
拟合点定义样条曲线的路径。您可以使用该属性更改给定拟合点的容差。您可以使用该方法添加拟合点。您可以使用该方法删除拟合点。您可以使用该方法查询拟合点的位置。您可以使用该方法更改给定拟合点的位置。FitToleranceAddFitPointDeleteFitPointGetFitPointSetFitPoint
Sub Example_NumberOfFitPoints()
    ' This example creates a spline object in model space.
    ' It then finds the number of control points for that spline.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    MsgBox "The Spline has " & splineObj.NumberOfFitPoints & " fit points.", , "NumberOfFitPoints Example"
(defun c:Example_NumberOfFitPoints()
    ;; This example creates a spline object in model space.
    ;; It then finds the number of control points for that spline.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(1 1 0
				     5 5 0
				     10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    (alert (strcat "The Spline has " (itoa (vla-get-NumberOfFitPoints splineObj)) " fit points."))
GMT+8, 2026-9-17 01:17
