AutoCAD 2024 开发者帮助
NumberOfFaces 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1097| 评论: 0|原作者: admin|来自: AutoCAD
获取 PolyfaceMesh 的人脸数。
object.NumberOfFaces
类型:PolyFaceMesh
此属性应用于的对象。
只读:是的
类型:长
的面数。PolyfaceMesh
Sub Example_NumberOfFaces()
    ' This example creates a PolyFaceMesh and displays the number of faces it contains
    Dim vertexList(0 To 17) As Double
    Dim FaceList(0 To 7) As Integer
    Dim NewPolyFaceMeshObj As AcadPolyfaceMesh
    Dim direction(0 To 2) As Double
    'Data for new PolyFaceMesh object
    vertexList(0) = 4: vertexList(1) = 7: vertexList(2) = 0
    vertexList(3) = 5: vertexList(4) = 7: vertexList(5) = 0
    vertexList(6) = 6: vertexList(7) = 7: vertexList(8) = 0
    vertexList(9) = 4: vertexList(10) = 6: vertexList(11) = 0
    vertexList(12) = 5: vertexList(13) = 6: vertexList(14) = 0
    vertexList(15) = 6: vertexList(16) = 6: vertexList(17) = 6
    FaceList(0) = 1:    FaceList(1) = 2:    FaceList(2) = 5
    FaceList(3) = 4:    FaceList(4) = 2:    FaceList(5) = 3
    FaceList(6) = 6:    FaceList(7) = 5
    ' Create new PolyFaceMesh object
    Set NewPolyFaceMeshObj = ModelSpace.AddPolyfaceMesh(vertexList, FaceList)
    NewPolyFaceMeshObj.Update
    ' Change the viewing direction of the viewport to
    ' better see the polyface mesh
    direction(0) = -1: direction(1) = -1: direction(2) = 1
    ThisDrawing.ActiveViewport.direction = direction
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ' Display number of faces in this PolyFaceMesh
    MsgBox "The new PolyFaceMesh contains " & NewPolyFaceMeshObj.NumberOfFaces & " faces."
(defun c:Example_NumberOfFaces()
    ;; This example creates a PolyFaceMesh and displays the number of faces it contains
    ;; Data for new PolyFaceMesh object
    (setq vertexList (vlax-make-safearray vlax-vbDouble '(0 . 17)))
    (vlax-safearray-fill vertexList '(4 7 0
				      5 7 0
				      6 7 0
				      4 6 0
				      5 6 0
				      6 6 6
    (setq FaceList (vlax-make-safearray vlax-vbInteger '(0 . 7)))
    (vlax-safearray-fill FaceList '(1
				    2
				    5
				    4
				    2
				    3
				    6
				    5
    ;; Create new PolyFaceMesh object
    (setq NewPolyFaceMeshObj (vla-AddPolyfaceMesh modelSpace vertexList FaceList))
    (vla-Update NewPolyFaceMeshObj)
    ;; Change the viewing direction of the viewport to
    ;; better see the polyface mesh
    (setq direction (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport direction)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
    ;; Display number of faces in this PolyFaceMesh
    (alert (strcat "The new PolyFaceMesh contains " (itoa (vla-get-NumberOfFaces NewPolyFaceMeshObj)) " faces."))
GMT+8, 2026-10-27 22:14
