Name 属性 (ActiveX)
指定对象的名称。 支持的平台:仅限 Windows 签名VBA: object.Name
属性值只读:
类型:字符串 对象的名称。 言论应用程序、文档:此属性仅返回文件名,不返回路径。 ToolbarItem:此名称用作工具提示文本。 MenuGroup:名称限制为 32 个字符,不能包含空格或标点符号。 栅格:此属性与属性类似,只是此属性不包含路径信息。ImageFile XRecord:对象所在的字典中对象的名称。此名称不表示对象的类名。 BlockRef:只能为块参照指定图形中有效块定义的名称。为块引用指定唯一名称不会自动创建新的块定义。若要创建新的块定义,请使用该方法将新对象添加到集合中。AddBlockBlocks 例子VBA: Sub Example_Name()
' This example creates a new layer. It then
' changes the name of that layer.
' Add the new layer
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Add("NewLayer")
' Find the name of the new layer
Dim layerName As String
layerName = layerObj.name
MsgBox "A new layer was created with the name: " & layerObj.name, , "Name Example"
' Change the name of the layer to "TEST". Note that behavior of the
' following code will be different for different objects. In some cases such as
' Block reference, changing the name means referencing to a new Block and therefore
' a Block with named "TEST" should already exist: otherwise an error will be
' returned.
layerObj.name = "TEST"
MsgBox "The new name of the layer is: " & layerObj.name, , "Name Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Name()
;; This example creates a new layer. It then
;; changes the name of that layer.
doc (vla-get-ActiveDocument acadObj))
;; Add the new layer
(setq layerObj (vla-Add (vla-get-Layers doc) "NewLayer"))
;; Find the name of the new layer
(setq layerName (vla-get-Name layerObj))
(alert (strcat "A new layer was created with the name: " layerName))
;; Change the name of the layer to "TEST". Note that behavior of the
;; following code will be different for different objects. In some cases such as
;; Block reference, changing the name means referencing to a new Block and therefore
;; a Block with named "TEST" should already exist: otherwise an error will be
;; returned.
(vla-put-Name layerObj "TEST")
(alert (strcat "The new name of the layer is: " layerName))
GMT+8, 2026-10-23 11:04
