AutoCAD 2024 开发者帮助
MRUNumber 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 776| 评论: 0|原作者: admin|来自: AutoCAD
指定“文件”菜单中显示的最近使用的文件数。
object.MRUNumber
类型:PreferencesOpenSave
此属性应用于的对象。
只读:是的
类型:长
“文件”菜单中显示的最近使用的文件数。
此属性的默认值为 4。
Sub Example_MRUNumber()
    ' This example reads the preference value containing
    ' the number of most recently used files that are shown in the File menu.
    Dim ACADPref As AcadPreferencesOpenSave
    Dim originalValue As Variant
    ' Get the OpenSave preferences object
    Set ACADPref = ThisDrawing.Application.preferences.OpenSave
    ' Read and display the preference value
    originalValue = ACADPref.MRUNumber
    MsgBox "The number of most recently used files that are shown is: " & originalValue
(defun c:Example_MRUNumber()
    ;; This example reads the preference value containing
    ;; the number of most recently used files that are shown in the File menu.
    ;; Get the OpenSave preferences object
    (setq ACADPref (vla-get-OpenSave preferences))
    ;; Read and display the preference value
    (setq originalValue (vla-get-MRUNumber ACADPref))
    (alert (strcat "The number of most recently used files that are shown is: " (itoa originalValue)))
GMT+8, 2026-11-2 10:13
