MomentOfInertia 属性 (ActiveX)
获取固体的惯性矩。 支持的平台:仅限 Windows 属性值只读:是的 类型:变体(双元素或三元素的双精度数组) 基于当前坐标系的 2D 或 3D 坐标。 言论转动惯量返回为定义为变体的 X、Y 和 Z 坐标。 例子VBA: Sub Example_MomentOfInertia2D()
' This example creates a region in model space.
' It then returns the MomentOfInertia for that region.
Dim curves(0 To 1) As AcadEntity
' Define the arc
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
radius = 2#
startAngle = 0
endAngle = 3.141592
Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
' Define the line
Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).StartPoint, curves(0).EndPoint)
' Create the region
Dim regionObjArr As Variant
regionObjArr = ThisDrawing.ModelSpace.AddRegion(curves)
ZoomAll
' Return the MomentOfInertia for the region
Dim regionObj As AcadRegion
Set regionObj = regionObjArr(0)
Dim momentOfInertia As Variant
momentOfInertia = regionObj.momentOfInertia
MsgBox "The MomentOfInertia for the region is " & momentOfInertia(0) & "," & momentOfInertia(1), , "MomentOfInertia Example"
Sub Example_MomentOfInertia3D()
' This example creates a box in model space.
' It then returns the MomentOfInertia for that box.
Dim boxObj As Acad3DSolid
Dim length As Double, width As Double, height As Double
Dim center(0 To 2) As Double
' Define the box
center(0) = 5#: center(1) = 5#: center(2) = 0
length = 5#: width = 7: height = 10#
' Create the box (3DSolid) object in model space
Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
' Change the viewing direction of the viewport to better see the box
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
' Return the MomentOfInertia for the box
momentOfInertia = boxObj.momentOfInertia
MsgBox "The MomentOfInertia for the box is " & momentOfInertia(0) & "," & momentOfInertia(1) & "," & momentOfInertia(2), , "MomentOfInertia Example"
可视化 LISP: (vl-load-com)
(defun c:Example_MomentOfInertia2D()
;; This example creates a region in model space.
;; It then returns the MomentOfInertia for that region.
doc (vla-get-ActiveDocument acadObj)
modelSpace (vla-get-ModelSpace doc))
;; Define the arc
(setq centerPoint (vlax-3d-point 5 3 0)
radius 2
startAngle 0
endAngle 3.141592)
(setq arc (vla-AddArc modelSpace centerPoint radius startAngle endAngle))
;; Define the line
(setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
(setq curves (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element curves 0 arc)
(vlax-safearray-put-element curves 1 line)
;; Create the region
(setq regionObjArr (vla-AddRegion modelSpace curves))
(vla-ZoomAll acadObj)
;; Return the MomentOfInertia for the region
(setq regionObj (vlax-safearray-get-element (vlax-variant-value regionObjArr) 0)
momentOfInertia (vlax-variant-value (vla-get-MomentOfInertia regionObj)))
(alert (strcat "The MomentOfInertia for the region is "
(rtos (vlax-safearray-get-element momentOfInertia 0) 2) ","
(rtos (vlax-safearray-get-element momentOfInertia 1) 2)))
;; The following example only applies to AutoCAD and not AutoCAD LT
(defun c:Example_MomentOfInertia3D()
;; This example creates a box in model space.
;; It then returns the MomentOfInertia for that box.
doc (vla-get-ActiveDocument acadObj))
;; Define the box
(setq center (vlax-3d-point 5 5 0)
boxLength 5
boxWidth 7
boxHeight 10)
;; Create the box (3DSolid) object in model space
(setq modelSpace (vla-get-ModelSpace doc)
boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
;; Change the viewing direction of the viewport to better see the box
(setq NewDirection (vlax-3d-point -1 -1 1)
activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
;; Return the MomentOfInertia for the box
(setq momentOfInertia (vlax-variant-value (vla-get-MomentOfInertia boxObj)))
(alert (strcat "The MomentOfInertia for the box is "
(rtos (vlax-safearray-get-element momentOfInertia 1) 2) ","
(rtos (vlax-safearray-get-element momentOfInertia 2) 2)))
GMT+8, 2026-10-23 18:49
