AutoCAD 2024 开发者帮助
ModelType 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 1016| 评论: 0|原作者: admin|来自: AutoCAD
指定打印配置是应用于模型空间还是所有布局。
object.ModelType
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:是的
类型:布尔
  • True:打印配置仅适用于“模型空间”选项卡,或者布局为模型空间布局。
  • False:打印配置适用于所有布局,或者布局为纸张空间布局。
Sub Example_ModelType()
    ' This example creates a plot configuration object
    ' and then finds the ModelType for the object.
    Dim PlotConfigObj As AcadPlotConfiguration
    ' Creates the MText Object
    Set PlotConfigObj = ThisDrawing.PlotConfigurations.Add("NewPlotConfiguration")
    ' Find the current ModelType
    Dim currModelType As Boolean
    currModelType = PlotConfigObj.ModelType
    MsgBox "The ModelType for the object is: " & currModelType
(defun c:Example_ModelType()
    ;; This example creates a plot configuration object
    ;; and then finds the ModelType for the object.
    ;; Creates the MText Object
    (setq PlotConfigObj (vla-Add (vla-get-PlotConfigurations doc) "NewPlotConfiguration"))
    ;; Find the current ModelType
    (setq currModelType (vla-get-ModelType PlotConfigObj))
    (alert (strcat "The ModelType for the object is: " (if (= currModelType :vlax-true) "True" "False")))
GMT+8, 2026-10-23 11:02
