AutoCAD 2024 开发者帮助
ModelSpace 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 844| 评论: 0|原作者: admin|来自: AutoCAD
获取文档的 ModelSpace 集合。
object.ModelSpace
类型:数据库、文档
此属性应用于的对象。
只读:是的
类型:模型空间
文档的集合。ModelSpace
Sub Example_ModelSpace()
    ' This example adds a line and a circle to model space.
    ' The line is added using a user-defined variable representing
    ' the model space. The circle is added without using the
    ' user-defined variable. Either use of the ModelSpace
    ' property is valid.
    ' Define the line
    Dim lineObj As AcadLine
    startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
    endPoint(0) = 4: endPoint(1) = 4: endPoint(2) = 0
    ' Add the line to model space using the mspace variable
    Dim mspace As AcadModelSpace
    Set mspace = ThisDrawing.ModelSpace
    Set lineObj = mspace.AddLine(startPoint, endPoint)
    ' Define a circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 4: center(1) = 4: center(2) = 0
    radius = 1
    ' Add the circle to model space without using the mspace variable
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
(defun c:Example_ModelSpace()
    ;; This example adds a line and a circle to model space.
    ;; The line is added using a user-defined variable representing
    ;; the model space. The circle is added without using the
    ;; user-defined variable. Either use of the ModelSpace
    ;; property is valid.
    ;; Define the line
    (setq startPoint (vlax-3d-point 0 0 0)
          endPoint (vlax-3d-point 4 4 0))
    ;; Add the line to model space using the mspace variable
    (setq mspace (vla-get-ModelSpace doc))
    (setq lineObj (vla-AddLine mspace startPoint endPoint))
    ;; Define a circle
    (setq center (vlax-3d-point 4 4 0)
          radius 1)
    ;; Add the circle to model space without using the mspace variable
    (setq circleObj (vla-AddCircle mspace center radius))
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-23 08:17
