MenuGroups 属性 (ActiveX)
获取会话的 MenuGroups 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_MenuGroups()
' This example uses MenuGroups to obtain a reference to the AutoCAD main menu.
' It then creates a new menu called TestMenu and inserts a menu item
' into it. The menu is then displayed on the menu bar.
' The menu item will be automatically removed when AutoCAD is restarted
Dim currMenuGroup As acadMenuGroup
Dim newMenu As AcadPopupMenu, newMenuItem As AcadPopupMenuItem
Dim openMacro As String
On Error GoTo ERRORTRAP
' Use MenuGroups property to obtain reference to main AutoCAD menu
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
' Create the new menu in this group
Set newMenu = currMenuGroup.Menus.Add("TestMenu")
' Add a menu item to the new menu and
' assign an Open macro (VBA equivalent of: "ESC ESC _open ")
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newMenuItem = newMenu.AddMenuItem(newMenu.count + 1, "Open", openMacro)
' Display the menu on the menu bar
newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.count + 1)
MsgBox "A new menu has been added to the ACAD menu system!"
Exit Sub
ERRORTRAP:
MsgBox "The following error has occurred: " & Err.Description
可视化 LISP: (vl-load-com)
(defun c:Example_MenuGroups()
;; This example uses MenuGroups to obtain a reference to the main menu.
;; It then creates a new menu called TestMenu and inserts a menu item
;; into it. The menu is then displayed on the menu bar.
;; The menu item will be automatically removed when the product is restarted
(if (= (strcase (getvar "PROGRAM") T) "acad")
(setq sMenuGroupName "ACAD")
(setq sMenuGroupName "ACADLT")
;; Use MenuGroups property to obtain reference to main menu
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) sMenuGroupName))
;; Create the new menu in this group
(setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
;; Add a menu item to the new menu and
;; assign an Open macro (VBA equivalent of: "ESC ESC _open ")
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
;; Display the menu on the menu bar
(vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
(alert (strcat "A new menu has been added to the " sMenuGroupName " menu system!"))
GMT+8, 2026-11-10 04:58
