LinetypeScale 属性 (ActiveX)
指定对象的线型比例。 支持的平台:仅限 Windows 签名VBA: object.LinetypeScale 属性值只读:否(对象除外)Group 类型:双 此值必须为正实数。默认值为 1.0。 言论对象的线型比例指定每个绘图单位的虚线点线型的相对长度。
例子VBA: Sub Example_LinetypeScale()
' This example creates a line and finds the linetype scale
' for the line. It then changes the linetype scale, and finally
' resets the linetype scale back to the original value.
Dim lineObj As AcadLine
Dim currLTScale As Double
' Create a Line object in model space
startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
lineObj.Update
currLTScale = lineObj.LinetypeScale
MsgBox "The linetype scale for the line is: " & lineObj.LinetypeScale, vbInformation, "Linetypes Example"
' Set the linetype scale of a Line to .5
lineObj.LinetypeScale = 0.5
lineObj.Update
MsgBox "The new linetype scale for the line is: " & lineObj.LinetypeScale, vbInformation, "Linetypes Example"
' Reset the linetype scale of a Line to what is was before
lineObj.LinetypeScale = currLTScale
lineObj.Update
MsgBox "The linetype scale for the line is reset to: " & lineObj.LinetypeScale, vbInformation, "Linetypes Example"
可视化 LISP: (vl-load-com)
(defun c:Example_LinetypeScale()
;; This example creates a line and finds the linetype scale
;; for the line. It then changes the linetype scale, and finally
;; resets the linetype scale back to the original value.
doc (vla-get-ActiveDocument acadObj))
;; Create a Line object in model space
(setq startPoint (vlax-3d-point 2 2 0)
endPoint (vlax-3d-point 4 4 0)
modelSpace (vla-get-ModelSpace doc)
lineObj (vla-AddLine modelSpace startPoint endPoint))
(vla-Update lineObj)
(setq currLTScale (vla-get-LinetypeScale lineObj))
(alert (strcat "The linetype scale for the line is: " (rtos currLTScale 2)))
;; Set the linetype scale of a Line to .5
(vla-put-LinetypeScale lineObj 0.5)
(alert (strcat "The new linetype scale for the line is: " (rtos (vla-get-LinetypeScale lineObj) 2)))
;; Reset the linetype scale of a Line to what is was before
(vla-put-LinetypeScale lineObj currLTScale)
(alert (strcat "The linetype scale for the line is reset to: " (rtos (vla-get-LinetypeScale lineObj) 2)))
GMT+8, 2026-10-22 07:10
