AutoCAD 2024 开发者帮助
Linetype 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 929| 评论: 0|原作者: admin|来自: AutoCAD
指定对象的线型。
object.Linetype
类型:所有绘图对象AttributeReferenceGroupLayerSubDMeshEdgeSubDMeshFaceSubDMeshVertexSubEntitySubEntSolidEdgeSubEntSolidFaceSubEntSolidNodeSubEntSolidVertex
此属性应用于的对象。
只读:否(对象除外)Group
类型:字符串
对象的线型。默认线型为图层的线型 (ByLayer)。
  • Continuous:默认线型,在线型符号表中自动创建。
  • ByLayer:对象图层的线型值。
  • ByBlock:对象周围块定义的当前块引用的线型值。
线型值标识用于绘制线条的一系列点和破折号。如果未指定线型,则当前活动线型将用于新图元。如果为实体指定了线型,则忽略当前活动线型。使用该属性可以设置或查询当前活动线型。ActiveLinetype
注意:无法以编程方式创建线型。可以通过使用 Load 方法首先加载线型,然后使用 Add 方法将其添加到集合中,将现有线型添加到图形中。Linetypes
Sub Example_Linetype()
    ' This example searches for the linetype DashDot. If it is
    ' not found, it is added from the acad.lin file. Then a
    ' line is created and changed to the DashDot linetype.
    ' Search the linetypes collection for the DashDot linetype.
    Dim entry As AcadLineType
    Dim found As Boolean
    found = False
    For Each entry In ThisDrawing.Linetypes
        If StrComp(entry.name, "DASHDOT", 1) = 0 Then
            found = True
            Exit For
        End If
    Next
    If Not (found) Then ThisDrawing.Linetypes.Load "DASHDOT", "acad.lin"
    ' Create the line
    Dim lineObj As AcadLine
    startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
    endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
    ' Change the linetype of the line
    lineObj.Linetype = "DASHDOT"
    ZoomAll
(defun c:Example_Linetype()
    ;; This example searches for the linetype DashDot. If it is
    ;; not found, it is added from the acad.lin file. Then a
    ;; line is created and changed to the DashDot linetype.
          doc (vla-get-ActiveDocument acadObj))
    ;; Search the linetypes collection for the DashDot linetype.
    (setq found :vlax-false)
    (vlax-for entry (vla-get-Linetypes doc)
        (if (= (vla-get-Name entry) "DASHDOT")
            (setq found :vlax-true)
    (if (= found :vlax-false)
        (if (/= (strcase (getvar "PROGRAM") T) "acadlt")
            (vla-Load (vla-get-Linetypes doc) "DASHDOT" "acad.lin")
            (vla-Load (vla-get-Linetypes doc) "DASHDOT" "acadlt.lin")
    ;; Create the line
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 4 4 0)
          modelSpace (vla-get-ModelSpace doc)
          lineObj (vla-AddLine modelSpace startPoint endPoint))
    ;; Change the linetype of the line
    (vla-put-Linetype lineObj "DASHDOT")
    (vla-ZoomAll acadObj)
GMT+8, 2026-9-6 18:45
