AutoCAD 2024 开发者帮助
LensLength 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 652| 评论: 0|原作者: admin|来自: AutoCAD
指定透视视图中使用的镜头长度。
object.LensLength
类型: PViewport
此属性应用于的对象。
只读:不
类型:双
镜头的长度(以毫米为单位)。
注意:此属性的值存储在 LENSLENGTH 系统变量中。
Sub Example_LensLength()
    ' This example creates a new paper space viewport.
    ' It then displays the lens length of the viewport.
    Dim pviewportObj As AcadPViewport
    Dim center(0 To 2) As Double
    Dim width As Double
    Dim height As Double
    ' Define the paper space viewport
    center(0) = 3: center(1) = 3: center(2) = 0
    width = 40
    height = 40
    ' Change from model space to paper space
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Create the paper space viewport
    Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
    pviewportObj.DISPLAY True
    ThisDrawing.mspace = True
    ThisDrawing.ActivePViewport = pviewportObj
    ' Find the Lens Length for the viewport
    Dim lenslgnth As Double
    lenslgnth = pviewportObj.LensLength
    MsgBox "The lens length of the paperspace viewport is " & pviewportObj.LensLength, , "LensLength Example"
(defun c:Example_LensLength()
    ;; This example creates a new paper space viewport.
    ;; It then displays the lens length of the viewport.
    ;; Define the paper space viewport
    (setq center (vlax-3d-point 3 3 0)
          width 40
          height 40)
    ;; Change from model space to paper space
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Create the paper space viewport
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq pviewportObj (vla-AddPViewport paperSpace center width height))
    (vla-Display pviewportObj :vlax-true)
    (vla-put-MSpace doc :vlax-true)
    (vla-put-ActivePViewport doc pviewportObj)
    ;; Find the Lens Length for the viewport
    (setq lenslgnth (vla-get-LensLength pviewportObj))
    (alert (strcat "The lens length of the paperspace viewport is " (rtos lenslgnth 2)))
GMT+8, 2026-10-23 09:17
