AutoCAD 2024 开发者帮助
LayoutShowPlotSetup 属性 (ActiveX)
2024-5-18 19:08| 发布者: admin| 查看: 924| 评论: 0|原作者: admin|来自: AutoCAD
创建新布局时切换“打印设置”对话框的显示。
object.LayoutShowPlotSetup
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:创建新布局时显示对话框。
  • False:创建新布局时不显示对话框。
此属性的初始值为 。True
Sub Example_LayoutShowPlotSetup()
    ' This example reads and modifies the preference value that controls
    ' the display of the Plot Setup dialog when a new layout is created.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
    originalValue = ACADPref.LayoutShowPlotSetup
    MsgBox "The LayoutShowPlotSetup preference is set to: " & originalValue
    ' Modify the LayoutShowPlotSetup preference by toggling the value
    ACADPref.LayoutShowPlotSetup = Not (originalValue)
    newValue = ACADPref.LayoutShowPlotSetup
    MsgBox "The LayoutShowPlotSetup preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.LayoutShowPlotSetup = originalValue
    MsgBox "The LayoutShowPlotSetup preference was reset back to: " & originalValue
(defun c:Example_LayoutShowPlotSetup()
    ;; This example reads and modifies the preference value that controls
    ;; the display of the Plot Setup dialog when a new layout is created.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-LayoutShowPlotSetup (vla-get-Display preferences)))
    (alert (strcat "The LayoutShowPlotSetup preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the LayoutShowPlotSetup preference by toggling the value
    (vla-put-LayoutShowPlotSetup (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-LayoutShowPlotSetup (vla-get-Display preferences)))
    (alert (strcat "The LayoutShowPlotSetup preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-LayoutShowPlotSetup (vla-get-Display preferences) originalValue)
    (alert (strcat "The LayoutShowPlotSetup preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-10-23 14:56
